Results 1 to 10 of 16
Thread: Enhanced CD
    Default Enhanced CD
    What is an enhanced CD? I've just ripped one to my server and whilst its ripped successfully, the CD and my ripper seemed to be having a right old tussle at the start
    Is it a regular CD with fake boobs ?
    There were some weird cd formats that came out about ten years ago. Popular in Japan I think. It's probably one of them. Can't remember what it was about them that supposedly made them special. Maybe someone else can recall?
    Think it has blue book class. Contains audio and data
    I'm Neil.
    SHM CD, Blu Spec CD, Blue Spec 2, HQCD, UHQCD, Platinum SHM-CD all are still CDs but made to a higher standard.
    Some info here http://www.cdjapan.co.jp/feature/shmcd_allabout
    I would have thought as they are still CDs that there would be no compatibility issues re discs being recorded.
    Regards Neil
    There were also glass cds at one point.
    I'm joe.
    Yeah, I've got 'Einstein on the Beach' for a kick-off.
    Really? You actually have one? I think they are worth a few quid now.
    I would look very carefully at the insert both front and back and see if it has the normal CD statement . If it does not then it does not meet the red book standards which happened with a number of CD's that had additional digital information that would try and prevent you from copying the disc when you put it in a PC . These faded away and were abandoned but there are still some examples out there.
    If the disc does have the CD statement then as noted above it is likely to one of the enhanced foramts that were prevalent in Japan but quite scarce here due to the price premium being asked.
    Quote Originally Posted by Bencat View Post
    recently bought a newish cd from atlantic that has the copy protection thing added. wont work on pc. it has now worked against them as i wont buy any more of their products.
