Page 36 of 48 FirstFirst ... 26343536373846 ... LastLast
Results 351 to 360 of 478
Thread: Advice on Quad power amps.
  1. #351
    Thanks all, this 303 fellow might be just what I'm looking for, mind you I'll be collecting a pair of Chario Syntar floorstanders that I got off here, and will see how they sound with the 306, I'm trying to rid my system of strident treble. Certainly doesn't hurt the pocket swapping around some of these Quad amps.
  2. #352
    Thank goodness somebody bought those Charios.
  3. #353
    I'm Ian.
    There's a serviced one for sale over at the 'wam. I'd always advise getting a serviced one or getting one serviced. The amplabs ones are also worth considering.
  4. #354
    I regard the 306 very highly, it's an extremely musical little amp. I've been using mine this morning through big Tannoys and the sound is all one could ask for really. I can't fault it.
  5. #355
    I'm Adrian.
    Hi Mike,
    Not sure if anyone has said this before but your Ruark Talisman II may be the strident treble culprit here, they are known to be a bit bright. Although a Naim Nait 5 can be quite up front, so the combination may not have been great. Having said that the Chario Syntar floorstanders may be a better match with the Naim.
    If you do go further with another amp then I would take your speakers with you to listen with what ever amp you are thinking about purchasing, getting a match that works can be tricky, get it right and it will you will be happy, worth the effort.
    Hope it works out,
    Adrian
  6. #356
    Hi Mike,
    That thought crossed my mind too.
  7. #357
    Hi Adrian,
    I'm using the Quad 306 at the moment, with a cheap passive - the little bear (£25 posted from China!!), I just bought some decent (or rather 'branded') speaker cable, the system is sounding a bit better, but I need to give it more listening time before I can judge properly, the Charios will land after Kegworth, so look forward to trying those. I listen to vinyl, but also CD, and when I can afford it I will by an offboard DAC such as a Beresford, as I still find cd listening to be the most strident.
  8. #358
    Hi Geoff, is yours standard or modded at all?
  9. #359
    Quote Originally Posted by IHP View Post
    I find the wam classifieds a bit hard to navigate since the site was overhauled.
  10. #360
    Standard.
