The little bear has arrived but I cannot connect the speaker cables to the 306 as the speaking sockets are loose, I connect, put lid on, then one or two of the cables come loose again, utter shite.
Is it your plugs? That's more likely.
I'm Alex.
Some of the Quad 4mm speaker sockets are a bit weak and break. About 1987 I bought the 405-2 upgrade for my 405, it included 4mm sockets to replace the original connector clips. Some years on, when plugging a 4mm plug, one of the sockets gave way and ended up pushed inside the amp. When I fitted the sockets, I did not over tighten the socket securing nuts.
Spendorman
I'm matt.
If you mean the 4mm banana plugs are loose in the 306 sockets, i'd imagine it's the fault of the banana plugs. Are they Naim plugs? I've messed about with them in the past and got to work properly. IIRC I just pushed something in the end to force the springy bit of metal out (sorry I don't know the technical name).
Don't understand why you are taking the 'lid' off Mike.
For loose speaker post connections obviously best to have them replaced when you can, but in the meantime suggest you use some form of strong tape (e.g. gorilla tape) to keep the banana posts bound to the amp speaker posts.
I've just had a look at the sockets on my 306. They are an older design with thin walled receptacle tubes. If you open the case you can crimp them gently with narrow nosed pliers to tighten them.
Should you wish to replace them, there is only one seller on ebay with these and there are eight pairs left: https://www.ebay.co.uk/itm/Panel-Mou...53.m1438.l2649
I just ordered myself a couple of pairs actually .
I'm Alex.
I'm Alex.
Thanks to the above replies & links. I've managed to connect the speaker plugs now, although the 306 sockets will need fixing. Listening through the little bear its ok, bit more pronounced than the Nait 5, but there's a slight harshness to the sound. I guess a pre amp costing £25 is never gonna be up to much?
