Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Balanced amp / output ?
    I'm Dennis.
    balanced systems were developed by pro audio because they are much more manageable from the S/N point of view, where in pro setups. frequent connecting and disconnecting are the norm, and often with long cable runs. They don't want to faf around with hum problems while a band is waiting to record for example.
    There are true balanced systems and also other variations which approximate to balanced. ATC active speakers for example have balanced I/Ps. As has been said, the circuits have twice the elements in them, and usually about twice the distortion, bt in reality it is probably still insignificant.
    I am happy with balanced pre and speakers, but FM O/P has an unbalanced O/P, and also my CD player, but it is very much more usual to feed a balanced I/P from an unbalanced O/P, than the other way round.
    I'm Allen.
    Quote Originally Posted by Light Dependant Resistor View Post
    Balanced audio finds use where you have need for long cable runs, it has ability to reject noise and offer wider dynamic range than unbalanced audio.
    However unbalanced can be made to similarly reject noise intrusion where opto coupling is used, and provide just as good, if not better ability for silence,
    in the process improving signal to noise ratio. The NSL32SR3 LDR for instance offers this ability, however requires much care with how it is powered.
    Marco ( The Headmaster ) might provide a review of a unit I sent to him late last year... if we are all good
    Some equipment that benefits from balanced audio includes phono stages, seen in the Audio Synthesis ADEQ product of the 1990's. Also headphones can be
    rewired for balanced audio and some amplifiers are provided with balanced inputs. Traditionally though balanced audio is used in recording studios and for live concerts.
    http://www.aviom.com/blog/balanced-vs-unbalanced/
    Whether balanced sounds better than unbalanced requires comparison using identical equipment. There is far more complexity with balanced audio. IMO the same advantages
    it offers can be attained with unbalanced, as explained above. That said some stages like phono benefit from being arranged with RIAA eq being balanced and turntables wired for balanced
    - which is due to the very small voltages involved. Taking this purist path requires attaining or building a balanced phono stage
    Generally converting unbalanced to balanced can be done with a THAT 1646 http://www.thatcorp.com/1600-series_...iver_ICs.shtml
    noting you need to regulate the current to each polarity of the devices power supply ( LM317/337 )
    Thanks Chris for the detailed reply
    I'm Neil.
    Subjectively I feel that balanced designs sound better, even when using short cable runs 1m. In saying that there is a positive benefit using long cable runs.
    I doubt the Toshiba 9500 has true balanced outputs, more likely just XLR outputs and it does not have a dual differential circuit. I can't be bothered opening mine up to look.
    Regards Neil
    I'm julian.
    In my experience, they both sound very much the same, but i have only used 1 metre runs of cable. If i have the option, at the same price point, i would go the balanced option.
    PS Audio Directstream DAC, modified Dennon DVD player, SP10, Trans Fi linear tracker, Stack audio streamer
    1980's Aloia 6L6 prototype, Cat's Whiskers Autum Leaves 300 B mono blocks, Definative Audio modded Rogue 88 Magmum 6550. Firebottle LDR battery pre. Classe 103, Herron VT2
    RFC Tannoy Cheviot's,Wilmslow Audio modified Chario Academy Millenium II's,Frankenstein DIY's, Oris Onken horns, Fostek full range drivers
    Ripnas etc
    I'm Pete.
    Hi All
    The Meridian G series amplifiers have both balanced xlr inputs and unbalanced rca inputs. Of possible interest is that when using the unbalanced rca inputs the signal is converted to balanced before the signal gets any amplification.
    I have a G55 - some detail here http://www.meridian-audio.info/show.php?compid=22 - using the rca inputs.
    It sounds much cleaner than the Meridian 205 monoblocks I was using and the 605 monoblocks a friend brought round to compare with the G55.
    I'm Clive.
    Without getting too technical XLR outputs are higher than RCA which in effect will lower the noise floor. Most of us will not readily be able to hear that but you pays your money and takes your choice.
    I use XLR connections in the main as I like the ability to lock cables securely in place. I have in the past experienced RCA cables working loose and hate having to get to the back of kit and giving the cable a wiggle.
    TV LG55B7 OLED
