Results 11 to 20 of 34
Thread: LUXMAN L10 ( poorly )
    Maybe a lazy relay
    Maybe a lazy relay
    It appears to work fine
    I’ll run it all day tomorrow and report back ( at least the trannies are ok )
    Default LUXMAN L10 ( poorly )
    The owner had a tt with his other luxman so perhaps it’s a faulty phono stage on this one ?
    Maybe or a bad plug
    Could be the relay contacts need a clean. Had an old amp with that problem.
    Gorgeous looking beast, would be interesting to give it the once over if you could bring it across.
    Hi Alan, thanks for your input, I do sometimes travel up your way so I may stop by ( and bring that phono stage I have too )
    I’ll let you know how I get on tomorrow.
    Cheers
    Bigman80 Guest
    Ok so the right channel does have a fault
    When I connect the multimeter to the left channel all is well but when connected to the right channel a small battery icon appears!! Voltage to speaker terminals?
    Anyone want a faulty luxman ?
