Dear Anthony
Mind you the following was published formerly on this site! Also you could have a look at
our tips.
When developing a SET amp around 1994 a student of mine remarked that he saw some "funny spikes" when looking at the output of the rectifier and with the oscilloscope switched to a high sweep frequency. I looked into it and came up with two solutions: an extra cap in parallel with the big electrolytic one or a resistor in advance of the rectifier.
We found that the spiky misery was also found in the amplifier circuitry (without fb).
I oppose to paralleling capacitors in the supply. We did this in the eighties, partly because the electrolytic capacitors then had a rising ESR from 100 Hz and up. That time is past, we now have much nicer caps. And .......... when filtering the supply with caps of different values in parallel there might rise a phase problem.
So we tried out some small resistors and the audible results were very good! Thereafter we used these spike-stop resistors in all our amplifier designs, be it class-A, -B or -D. And, of course, also in our pre amps.
A few years later we found that the Philips company uses this technique since the early seventies in all their medical instruments! So there's nothing new.
Being an editor of an audio magazine at that time we also had the possibility to try this on a variety of amplifiers from various manufacturers. In all cases we had good results.
After publishing this "trick" a lot of audio amateurs tried it with good results, even some guys around the "Art of Sound Forum".
Regarding the loss of dynamics one should realize that the main source for instantaneous power is in the big capacitors. These are loaded from the transformer of course, but then we have to do with the internal resistance of the transformer + rectifier. Using a small value resistor the loss of dynamics is quite small (in power amps we use 0,1 Ohm!). In preamps such as the one in the article the current from the supply is quite steady so no dynamics whatsoever are involved.
BTW when using "fast recovery" diodes or rectifiers the resistors are not sufficient. Then each diode should be paralleled with a small capacitor, preferably a polycarbonate one.
John
