Page 1 of 4 123 ... LastLast
Results 1 to 10 of 37
Thread: Help needed: CD Transport
    I'm Jesper.
    Default Help needed: CD Transport
    Hi fellow music lovers
    I’m in the process of assembling, what I hope, will end up being a serious setup
    So far I have the speakers, DAC(preamp), AMP & power management, that I believe is “up” there
    Benchmark DAC2 HGC
    Bryston 14B SST2
    ATC SCM 100 Classic
    & a Furman P2300 IT E
    These are my “keepers”, I do have a decent CD player, a TEAC PD 501HR, nice little device
    But here is where your Help would be most appreciated - I’d love to upgrade to a really great CD transport
    I’d love to hear your thoughts on this matter & off course what you use your self
    All inputs are highly appreciated!
    Finding and getting a demo of high end gear here in little Denmark is not easy
    -I have tried to get a demo of the Bricasti M5 for some 6 months now, the only way so far is a privat demo a nice guy have offered me, the dealer only takes home units when you buy one
    Thanks upfront for your time
    Jesper “studio Gear head”
    Are you able to get a dem of a CEC transport? We demo'ed one a couple of years ago against a Project RS Box, and although we purchase the Project since it was only to be used as a 2nd source, the CEC was better. One cdp I would love to hear would be this https://www.hifisentralen.no/forumet...onse-nr-202429
    I'd stick with the TEAC. There's only so much a cd transport can contribute and the TEAC is almost certainly already doing it. Plus it looks pretty cool too.
    Martin
    Technics SLP1200 CD Player * Nelson Pass DCB1 Pre amp / Krell KSA50S Power amp * JM Lab Electra 926 loudspeakers *
    'You fool! To think that your ape-brain could contain the full knowledge of the Krell!'
    I'm Neil.
    Better transports make a massive difference to sound quality in my direct experience over the years. Last time I had that reinforced was comparing two esoteric transports, the dearer of the two destroyed the cheaper. Over the years I have done comparisons and owned transports from companies like Marantz, Micromega, Audiomecca, Meridian, Deltec, Teac, Wadia, Esoteric, to name a few and in every case the better quality the transport the better the reproduction of music was. Digital cabling is important as well.
    My advice seek out a quality used transport from Esoteric, CEC, Micromega, Audiomecca or similar. Bits are bits argument holds no water and the better the transport the better the music will be, and a dedicated CD transport is the preferred path, not a DVD player.
    Regards Neil
    System 1 (Living Room) : Vinyl: AMG Giro Turntable, AMG Giro Reference PSU, AMG 9W2 Tonearm, AMG Reference Armcable, Air Tight PC3 MC Cartridge PhonoStage: Passlabs Xono Digital: Esoteric P5 SACD Transport and Esoteric P 5 DAC, Sony HAP Z1es Digital File Player + Audioquest Jitter Bug, Computer Audio: Veracity Audio Mystra DAC + HP laptop + iFi Audio i Power, Wireworld Starlight USB + Audioquest Jitter Bug Tuner:Kenwood KT 7020 Cassette Tape: Nakamichi CR5e Amplification: Pre-Amplifier Meridian G02 Power-Amplifier Meridian G56 Speakers: Anthony Gallo Reference 3.1 Audio Cabling: Signal - Atlas Mavros, Audience AU24 Speaker - Atlas Mavros. Mains Cabling: Audience AU24, Analysis Plus, TCI. Mains Distribution: Mark Grant Distribution Blocks, Mark Grant DC Blocker Equipment Tables: Target Audio B series + Track Audio Isolation Spikes Isolation/ Platforms: Bright Star Audio Isonodes, BASE 01, SSC Platforms.
    System 2 (Music Room) : Vinyl: Turntable 1 Loricraft Garrard 401 Turntable + SME 5 Tonearm, Graham IC70 Tonearm Cable + VDH MC10 cartridge Turntable 2 Modified Technics 1200 turntable + Triplannar 7 Tonearm + VDH Frog Gold Cartridge + Paul Hynes SR7 PSU Turntable 3 SME Model 20 Turntable + Graham Phantom Tonearm + Graham IC70 Tonearm Cable, Ortofon MC5200 Cartridge PhonoStage: Balanced Audio Technology VK10se Digital: Moon Andromeda CD Player, Toshiba 9500 DVD Audio Player Computer Audio: AMR DP777 DAC + Dell Laptop + iFi Audio i Power + JKenny JKSPIDIF + Wireworld Starlight USB Tuners: Kenwood 8300 Tuner, Revox B760 Tuner, Leak Troughline Tuner + EAR Stereo Decoder, Magnum Dynalab Signal Sleuth FM Amplifier ReelToReel Tape: Revox B77 mk 2, Revox A77 mk3, Sony TC-377 Cassette Tape: Nakamichi DR10 Pre-Amplifier: Balanced Audio Technology VK52se Power-Amplifier: Music Reference RM200 mk1 Speakers: Anthony Gallo Reference 3.5 Audio Cabling: Signal - Audience AU24, Kimber KCAG, Audio Note ANVs, Barry Hunt Cables Speaker - XLO Type 6. Mains Cabling: Audience AU24, TCI. Mains Distribution: Mark Grant and Russ Andrews Equipment Tables: Clear Light Audio Aspekt Tacks Isolation/Platform: SSC, Bright Star Audio Isonodes, Naim Frame Record Cleaner: Hanns Audio
    System 3 (Bed Room) - CD Player Marantz CD7, Headphone Amplifier: Audio Valve RKV2 OTL Valve Headphones: Grado GS 1000, Sennheiser 560 Ovation2, Sennheiser 410SL
    Good advice there from Neil. I agree with all that.
    "when common sense, logic and plausibility are excluded. All that remain are foolishness and lies"
    Another plus from me, a good transport makes a difference. Macca, I would think the reason your Technics sounds so good is because it has a good transport.
    Not disputing that the transport can make a difference and in some case a big difference. I just don't think it will in this specific case. The Teac has separate power supply for the digital stage, looks well engineered. There's a limit to how good you can get.
    That's just, like, my opinion of course. But then opinions was what was asked for.
    Martin
    I'm Richard.
    Talking of esoteric, try this. I reckon they think it makes a difference
    https://www.ebay.co.uk/itm/ESOTERIC-...cAAOSwH2tbXILm
    I'm Alex.
    I have an Audionote CDT3 transport. One of the reasons for buying it, is support. If anything goes wrong, Audionote have large stocks of the Phillips Pro mechanisms to keep it running for years to come. It sounds very good as well :-)
    I have two CD transports one is a Meridian 200 and it works well and sounds fine . In isolation I do not think you would have much of a feeling that your are missing much if anything . However in my main music system I have Theta Data Basic transport and even I have to admit that it is just better in all areas . I bought it second hand for around £250 about ten years ago and I have never felt the need to improve on it . it is not the last word on any testing specification chart but it is still the most musical Transport I have heard .
    Problem is you need to hear as mant Ransports in your system and against your TEAC . I used to have a TEAC P500 unit which was superb but proved to be a little unreliable which was a real shame . I would suggest if you can you try and orgainse a Transport Bake Off and ask anyone coming to bring a Transport which will give you a chance of hearing a number of units in your system and seeing how the TEAC compares .
