For sure... ALL known and applicable variables *must* be taken into consideration, and effectively addressed, in order for the test results to be as accurate as possible. That applies when testing anything!
A thought crossed my tired mind, has anybody tried Russ Andrews shorties? Some of the reviews seem to suggest similar improvements to grounding boxes... https://www.russandrews.com/shorties...90000/#reviews
They stop all nasties getting inside, but look a bit expensive for what they are.
Kevin
Yes, I've been using them for years, and with good success...
I meant to mention this much earlier in the thread, but forgot. Furthermore, I've always been able to hear the (subtle, not massive) detrimental sonic effect of having more than one piece of equipment plugged into my preamp, when listening to music, which is why for 'serious' listening sessions, I always disconnect whatever kit isn't being used, and fill the empty inputs with 'Shorties'.
Therefore, if that is what this grounding box (and others like it) are doing, but on a larger scale, then I can safely say that *for me* it works!
My System:
CDP - Pioneer PD-91
My System:
CDP - Pioneer PD-91
But shorties can’t be any good as they are not expensive enough?
Kevin
They are extortionate. £18 a pop.. Cheaper using tinfoil
Yes. You could make your own much cheaper.
Kevin
