Page 45 of 71 FirstFirst ... 35434445464755 ... LastLast
Results 441 to 450 of 706
Thread: Grounding boxes - The real deal
  1. #441
    I'm Adam.
    Quote Originally Posted by Mr. C View Post
    I'll expand, the signal to noise ration of a top notch CD player really is so close to 96dB, by the test results the resultant conclusion would indicate the SQ of the system it was plugged into would drop below cassette tape playback capability
    That’s not really a valid comparison. If you look at the measurement figures, you’ll see that the 40dB increase in noise took the figure from -150dB up to -110dB. These are not levels of noise that you hear in the same way as cassette hiss, but it will still potentially alter the sound.
  2. #442
    I'm Tony.
    Quote Originally Posted by Beobloke View Post
    Morning Adam
    I must admit I didn't really have a close look at the graph that was cited so my error there.
    Human hearing has a dynamic range of around 140dB (though that does vary according to frequencies) so I would suggest that yes, it would be more than perceivable to most individual's hearing to that amount of 'induced noise' What is seen on the AP graph is pretty substantial (Though not connected to an audio system) and no one would wish to purposefully place that amount of noise into any audio system.
    Perfectly logical rational behind the length of the cables and pick ability of said 'aerial' though if you inspect the leads that entreq use they are rather basic in terms of various rudiments of cable manufacturer imo. This in itself will not be solely responsible for the result I would suspect but it sure isn't going to help!
    While were are on the subject of human hearing although we have a so called 20hz<>20Khz range (hence the Nyquest theorem in the red-book standard, which was 22.05Khz (half the 44.1Khz frequency range) the brick wall filter emerged early on 20-20Khz.
    However we may not be able to physically 'hear' above those frequencies and lower as we get older, I am 52 and have me hearing checked every three months by a qualified audiologist (not spec savers lol) luckily I still have just on 15Khz available out of the 20Khz.
    However we can perceive frequencies at a higher rate, although we may not actually 'hear' them yet we sense them. Many musical instruments have bandwidths which far exceed the 3rd harmonic. If these were recorded with a flat 20Khz microphone they genuinely would not sound as they we would normally associated. Recording studio's uses microphones which capture far higher frequencies to enable realistic presentation after being squeezed into red book format.
    Coherent Systems
    Real high end sound with musicality not hifi
  3. #443
    To my knowledge there is no evidence that we hear above 22Khz, I'd be interested in anything you can reference that documents that we can. Nothing recorded prior to about 2000 uses a mic that can capture over 22khz. Most mics in use now do not do that either.
    All the great recordings in rock, pop. classical and jazz were made with recording equipment that struggled to capture 20Khz. Are we now saying that they do not portray instruments realistically?
    Added to that, even with higher bandwidth mics available, many artists and producers favour vintage mics that again, cannot record frequencies over that level. You're really on a hiding to nothing with that line of argument Tony. It has zero credibility.
  4. #444
    No to mention all the speakers that do not have any response over 22KHz. QUAD ESL? Tannoy DC...?
  5. #445
    One of the most well known Mic's in the business! https://en-de.neumann.com/u-87-ai#technical-data
    Nikola Tesla
    www.tubedistinctions.co.uk
    Matthew 5:10
  6. #446
    Check out the response of some of the old ribbon mics. Not so sure about any accompanying pre-amp/amp circuitry though.
  7. #447
    or the tape machines....
  8. #448
    Some of those claimed responses up to 30 or 40 kHz. Dunno at what level limits though.
  9. #449
    I'm Clive.
    Even with 30kHz to 40kHz.....the numbers sound big but we're only talking about half to one octave higher than 20kHz.
  10. #450
    Quote Originally Posted by anthonyTD View Post
    And what's it powered by? Lovely glowing bottles [or at least the originals were] - best technology ever invented!
