That's fair enough, Martin, as it's your experience so far. Mine is different. If you'd been there when I swapped out the SMPS units for the router and hard-drives, and installed Dunc's linear PSU, in my streaming set up, you'd easily have heard the difference with that alone, trust me
Yes, but regardless, it proves that replacing them in that area with something better, works!
In terms of your other point, often with these things you don't notice any difference in quick-fire A/B comparisons, but only after a period of time, one way or the other... After all, it's the reason why our systems often sound better in the early hours of the morning, when there is less of a drain on the mains, and a lot of the noisy crap has been switched off for the night.
*That* is essentially what you're achieving on a smaller scale when you unplug all unnecessary noisy devices at home. However, it's most likely you're not hearing any difference because you don't have much of that shit in use in the first place
Right, time for pasta!!
I’ve just counted 25 smps wall warts ‘in use’ throughout the house
