Page 22 of 71 FirstFirst ... 12202122232432 ... LastLast
Results 211 to 220 of 706
Thread: Grounding boxes - The real deal
  1. #211
    "The prejudice I was referring to was in relation to the propensity of staunch objectivists to arrogantly dismiss everything that doesn't fit with their scientific belief system"
    What actually is gong on, is a corruption of the scientific method to provide comfort to the espouser; they are not usually entirely objective, and mask their lack of intellectual rigour with a stance of arrogant aggression.
    In my time with Auntie, this was a cultural norm, the body language expressing contempt for anyone less qualified, as though they must implicitly be inferior in all they thought and did.
    Brilliant, Dennis. We haven't had a 'Captain Insightful' post from you for ages! Needless to say, I think you're *spot on*. It certainly reflects my experience, and my view of what's happening.
    You're last sentence, however, is especially revealing and rather interesting. Would you say that this "cultural norm" has bred the type of arrogant aggression and dogma, often displayed on forums by 'engineering types'/objectivists? Also, what caused this "cultural norm" to start with, and which also appears to have bred the (often unjustified) sense of superiority you've mentioned?
    Now before someone jumps down my throat, I'm NOT saying that the above applies to all engineers, far from it [there are many on here who don't display such traits], but I have to say it certainly applies to a goodly dose of them I've encountered on forums, since I first stared posting on them - and it has caused no end of friction and fallouts, especially when people like me won't just put up with it.
  2. #212
    Weirdly enough it's the SMPS units that generate more RFI than the mobile phones.
    RFI simply stands for radio frequency interference, and it isn't necessarily air borne.
    All the SMPS units switch at radio frequencies.
    Yup mate, I know, and your (valid) post simply backs up what I've been saying, and which is why you need to eradicate them wherever possible. With mains quality, we've never had it worse - and it's not going to improve anytime soon either!
  3. #213
    alas ive loads of smps; not a lot i can do about it really either.
    I'm Adam.
    No thoughts on post #200?
    All good! I shall continue to put my side of the case, then, but will of course refrain from going all Frank Drebin on anyone and calling them "Mr. Poopy-Pants".
  5. #215
    I'm AMusicFanNotAnAudiophile.
    Eradicating them altogether is not going to happen - they use something like 20% of the power a linear psu does.
    If every manufacturer of electrical devices moved back to using linear PSUs the power requirements nationally would exceed generating capacity.
    SMPS manufacturers should make them with a much higher standard of filtering, so that the use of SMPS has no effect at all on locally connected euipment, but that will in turn have a knock on effect on the cost per unit to manufacture.
    So it won't happen.
    Ferrite chokes are a relatively inexpensive way of significantly reducing mains borne RFI.
    The
    Chris
    Common sense isn't anymore!
  6. #216
    Honestly if the outside world read this post regarding the subject of a grounding box they would be amused and bemused like I am.
  7. #217
    I'm Adrian.
    I thought some of you might find this an interesting and informative read in relation to Ground/Earth loops, noise and inductance issues with all sorts of stuff, including video and hifi.
    Page 56 for about 10 pages are useful info, 99-101 are quite informative, but it is all good stuff.
    There is a load of information further on about noise elimination methods and what works and what does not.
    It is from Bill Whitlock, President
    Jensen Transformers, Inc.
    Life Fellow, Audio Engineering Society
    Life Senior Member, Institute of Electrical & Electronic Engineers
    https://centralindianaaes.files.word...notes-v1-0.pdf
    I am sure you can then make educated conclusions as to whether a grounding box will or won't work depending on what you find inside it.
    Referring to the 2 previous posts from Marco and Pharos I would suggest people have a read of the above, it is lengthy but IMO deals with various aspects of Earth/ground and the issues of interference and noise floor, and from an engineer in the field so to speak.
  8. #218
    Course you can...
    Firstly, minimise the amount of gear you use with SMPS in the first place, and in terms of audio equipment, only use stuff that's fitted with a fully-regulated linear PSU. If you have to buy older gear to facilitate that, then so be it. Secondly, when not in use, disconnect all non-essential items with SMPS from the mains supply (computers, phone chargers, etc), during times when you're listening to music.
    Thirdly, where possible in the audio chain, replace SMPS units with fully-regulated linear PSUs, such I've had done in my streaming set-up.
    Both of my hard-drives and router are all powered from a dedicated linear PSU [designed and built by Duncan for less than £300], and their original cheap, shitty (noisy) SMPS ones chucked in the bin - and all of that has allowed my streaming system to perform better, sonically.
    As they say, 'Where there's a will, there's a way'...
  9. #219
    So it won't happen.
    I agree with all of that, but it's still no excuse to be lazy or apathetic towards the situation, as I've just outlined, if you *truly* want the best sound!
    The
    The what? The chances of Man City winning a European trophy sometime soon are slim?
    Only kidding!!!
  10. #220
    I've only got the TV and cable box using smps - I did try disconnecting them entirely when listening (they would normally be in 'standby' mode - made no difference I could discern.
    Also sometimes listen with the tv on and the sound down, again can't hear any difference.
    Okay so I can't say for certain from that one instance that the whole SMPS thing is a none issue but I suspect it is. Maybe if you have loads of the things plugged in all over the house it might be more noticeable.
