The PurifierBlock is designed to vastly improve sound and picture quality of your HiFi, Home Cinema, Audio Visual Equipment using the highest quality components and Kimber Internal Wiring.
Eight SuperSockets offer a good tight fit around plug pins for efficient contact and reduced impedance.
MegaClamp spike protection fitted.
I have many Purifiers and filters improving the sound in my current system.
The block is fitted with a grounding terminal to run an earth cable. I've never tried this myself.
Current model £800 from Russ Andrews
Needs a C19 IEC plug or cable which I can provide. Please ask for price. Will list all cables soon.
Russ Andrews current product
https://www.russandrews.com/the-powe...-supersockets/
Besides the Russ Andrews HC PowerKord I have many others you can listen to and I can supply.
Prices range from £50 to £1200. Upgrades on upgrades on upgrades. Each step brought a step up in sound quality.
Width 136mm Length 330mm Green terminal on end adds 25mm Height 136mm
Demonstration in North West Surrey, bring your own kit to try if you like
£250 plus delivery of your choice to UK or worldwide
Give me your postcode and I can price delivery for you
