Does anyone know if the Cambridge CXC CD transport utilises an output transformer for galvanic isolation of the SP/DIF?
If so has anyone looked at the output waveform on a scope?
any clues here ?
https://www.youtube.com/watch?v=oS8fumFE-e8
Eric Bibb
[QUOTE=hifinutt;1051679]any clues here ?
Unfortunately not. If it’s got one of those small digital transformers the S/PDIF wave form will likely not be good. I’ve not come across one of those transformers that Marantz and Phillips used in their CD players that did not distort the S/PDIF signal.
I did some experimentation on this, I even used an expensive Lundahl digital isolation transformer that was not much better.
I have an old Yamaha CDX653 that uses the Philips TDA1541 DAC chip and the S/PDIF digital output is via a transistor buffer with no transformer and the output waveform is really clean.
I'm Raphael.
Hi there,
I got a CXC transport at Christmas.
I am running it into an MDAC and then to Icon Audio pre and 845 Mono blocks to B & W Nautilus 804s - certainly the best CD sound I've had so far - way ahead of the rather expensive Denon 3800-BD player that I was using previously ( and several other CD players beforehand )
I don't know re the transformer on the SP/DIF but more than happy to put the 'scope on the output - what exactly are you looking for?
Provided there aren't security seals on it I am happy to open it and have a look inside.
Kind rgds,
Ray
good to hear such good results from the cxc and mdac . very modest price . all these dacs seem so expensive these days
Eric Bibb
I'm Shaun.
Yeah, using a Cambridge CXC into an MDAC modded by John Westlake. Love the sound and the filter options.
