Results 1 to 10 of 15
Thread: Tracking Force Scales Accuracy
    I'm Robert.
    Default Tracking Force Scales Accuracy
    Is there a big diiference between the accuracy of some tracking force scales and others ??
    For instance, something like this one https://www.ebay.co.uk/itm/Digital-S...-TL0:rk:2:pf:0
    against something far cheaper like this made in China jobby https://www.ebay.co.uk/itm/Digital-C...C~CH:rk:9:pf:0
    My System:
    CDP - Pioneer PD-91
    I'm Adam.
    I remember years ago one of the hi-fi magazines (I think it was Hi-Fi World, IIRC) doing a test of all the digital gauges on the market to see which was most accurate. They also threw the old Garrard SPG3 in for a laugh, and came to the surprising conclusion that it was one of the cheapest, but also one of the most accurate!
    I'm Simon.
    Double sided sticky tape a credit card to a cheap Chinese one to keep the magnets apart and they're mega, better than o.o5g accurate, ime
    I'm Graham.
    Hi Robbie,
    I find the cheap Chinese one works fine. Only issue is the replacement battery. I bought LR43 supposedly same as AG12 fitted originally. However with the Duracell LR43, the display is dimmer and it ran out quickly. I will be trying cheaper AG12 batteries next time as the original AG12s lasted a long time.
    The digital scale is certainly easier to use than the Shure scale I have and seems at least as accurate.
    I'm Blake.
    Very likely they are both made in China, and quite possibly in the same factory. Probably both manufactured by Canrong.
    Big difference between the two scales is that the more expensive model has resolution to 3 decimal points or 1/1000th of a gram; the less expensive model measures only to 2 decimal points or 1/100th of a gram.
    The more expensive model also appears to use AAA batteries which I would view as a positive. The model that I used for about 7-8 years before it died that had the higher resolution used the button/watch type batteries that are typical in the lower priced/lower resolution models. I now have a couple of the cheaper, lower rez models that are about $10.
    If you search Ebay, the higher resolution model (unbranded) should be able to be found around $50-$60. These models also have, IMO, slightly better build quality and may last longer. But the reality is that you can buy 4-5 of the low rez models for the same price and measuring to 1/100th of a gram is still pretty decent.
    When I had the higher resolution model my wife was a research tech. I had her take that $50 scale into the lab and weigh a number of items up to 5 grams with it and compare the readings with very, very expensive scales in the lab. The $50 digital scale was accurate to within .007 grams when tested against the other scales.
    Within its resolution envelope, I'd expect the lesser scale to be just as accurate, and much more precise than something like the Shure if that matters to you. With cartridges that I run I hear differences in VTF of around .02 or .03 grams so it does to me.
    got one of these to try against my usual similar to one you pointed to. accurecy is very similar. this one is prettier and has a bigger target area. its really a jewellery scale
    https://www.ebay.co.uk/itm/Gold-200g...item2ac10d11cd
    I'm stuart.
    Quote Originally Posted by blake View Post
    Really? That's about the weight of a grain of sand. So are you adjusting the VTF for every LP you play as the variation in the thickness of an LP will give you more of a variation in VTF than 0.02g? Also, unless every LP you have is super flat then you will get more than 0.02 variation in VTF as the record plays.
    I'm Adrian.
    Hello Blake,
    I found it very interesting that you think you can hear differences in sound with changes of 0.01grams. What do you think is the reason for this? Do you think it might be that you are on the edge of the weight you Jelco arm can take with you Headshell and cartridge combo, so that slightly changes in weight emphasise the bass or result in resonance issues?
    I believe Blake can now change his name to Golden Ears.
    Struth - That's a nice looking scale you linked to.
    Quote Originally Posted by antonio View Post
    its good for money; a bit different.
