Gents,
have a look at this:
http://denon.jp/products2/dp1300mk2.html
Has this TT the same engine assembly of the SL 1200, or what?
Gents,
Giovanni.
If you mean the small photo of the motor coil and bearing assembly, it does look familiar. Do you think it's built for Denon by Technics?
Nice looking deck.
Oh well... I really don't know if Denon made a thing like that, but it seems like seeing the magnet and the coils of the SL 1200.
I read about this TT being very good, and as long as I know is the only DD budget TT other than the SL 1200 currently on the market
Now I'm just thinking about the words of Marco, talking about the top-of-class DD engine of the SL 1200. If Denon is using that engine, than Marco is right.
BTW if you take a closer look to the tonearm... it seems to be the tonearm of... ?
Giovanni.
Thats a pretty Turntable- is it available here and how much?
Me so horny- Impulse H6 Horny
If it is the Techie motor (and it does appear to be so), then I think Hayden labs should consider bringing a few over to trial...
sorry, only for jap market. It should cost about 1500 € (1300 GBP). I read it can be found as direct import in USA
EDIT: some better pics here: http://www.hifido.co.jp/KWDenon+DP-1...9167-25667-00/
Giovanni.
No it isn't the Technics motor or any other Technics parts. Its made by the company who also do the Stanton DD. Han Pin? or something like that.
Sorry, guys....
Beauty is in the eye of the beholder, I guess.... I've seen those Denon's before and they do nothing for me whatsoever.
The arm looks really cheap (about as good as a stock Techy arm, at best) and the 'orangy' plastic looking wood and the whole finish of it is a bit blingy - nope not my thing at all.
There are some very nice Denon Direct-drive T/Ts around, but IMO that's not one of them.
Give me an SL-1210MK5G or a Pioneer PL-71 any day!
I'm with you marco... Maybe it's just the photos but as you say it looks really plasticy! Not my bad neither!
If you want a good direct drive TT and it's neither a Technics or an EMT, then there is only one Denon to go for: the Denon DP-100M.
http://www.thevintageknob.org/DENON/DP100M/DP100M.html
Just get rid of the arm and fit something decent!
Regards
