Hi
I was wondering if anyone has tried this PSU with the 401. I have heard other types mentioned on the forum but have the opportunity to get this at a good price. Any experiences? Thanks
https://www.classichifi-shop.co.uk/p...pply-unit-psu/
I'm Drew.
Hi
try and buy a second hand Nigels Speed Controller, or even make your own. The cost will be approx 50% cheaper.
Whilst it looks superb, in my opinion, you really don’t need it unless your electricity supply is truly disastrous.
Personally, I’d buy £900 worth of records instead...
