Looking for a dust cover for my Nottingham Analogue turntable, any recommendations?
Regards
Robin
Pathos Classic Remix Amp, dac
Cyrus Signature phono stage
Eversolo DMP-A6
Cyrus CD i
I'm Peter.
Look no further than Widowsons.
https://www.acrylicdisplaycases.co.u...case-base.html
Superb quality (any custom size)
Hi Robin, I bought mine from the eVilBay seller 'ashpope123' to fit on my tweaked Thorens TD145. If you don't necessarily want/need the fully enclosed dust cover, visit his store on the bay that seems rather "empty" at the moment. But he use to have those other acrylic cut and bend leaf (made in the UK) that you just drop and rest on the platter and that has "wing" to cover the tonearm... Without that rest on the plinth like that for the TD160... as shown on his shop. If ever PM him. I really love that discreet, clean and "modern" design for the worst part of any turntable: the dust cover. Their service is TOP as well. Or see for those 'Michell Eng.' ones... Cheers, Tim
- Cart Denon DL-102 in bakelite Ortofon SPU 'G' type headshell
- TA SME 3009 'Improved' converted in heavy mass with detachable headshell
- TT Thorens TD160 'E' totally tweaked driven by an 'Eagle & RoadRunner' PSU & tachometer combo
- Matts top to bottom: leather, cork, felt & 12" vinyl
- Pre-amp 'Modulis' Isem
- Amp 'Exampli' Etalon 2x40W
- Speakers 12" Leak 'Sandwich' first generation creatively recapped
Looking for one that will cover the complete turntable basically a a clear box
Regards
Robin
Eversolo DMP-A6
Cyrus CD i
I'm Peter.
Something like this (although This sits on top of the Plinth)
Mind you, Any design (Height / width / depth is available).
Hi Robin,
Can definately recommmend https://plasticonline.co.uk/turntabl...le-covers.html
My retripped moving coil required less tracking force meaning that with the counterweight slightly further back it was just touching my Techies dust cover.
As a result I came across Plastic Online who do a bespoke turntable dustcover service.
They do standard measurements, where you can then add / advise your hand and rear cable access cut out measurements - it's very easy
I then found some techie replacement dust cover rubbers on Ebay which although not a tight fit (I havnt glued them) do the job well.
286 by [url=https://www.flickr.com/photos/152233952@N07/]
287 by [url=https://www.flickr.com/photos/152233952@N07/]
My System:
CDP - Pioneer PD-91
