This would most likely be best done as a poll but here goes anyway. Which glue/adhesive/method is best for LP cover repairs?
Contact adhesive, narrow and swallow
ordinary run of the mill glue stick...the lipstick twist out type...works perfectly
https://www.ebay.co.uk/itm/172575700279
'ANDSOME IN THE SUMMER..'ORIBBLE IN THE WINTER. Barney Milne
Cambridge Audio CXN, Seagate nas drive, Michell Gyrodec SE, SME309, Benz M2 Ruby cantilever, Denon DL103, Primare R32, Densen D20, Densen D30, Cambridge Audio 840A V2 integrated, Pioneer SX-N30AE Network Stereo Receiver, Roksan Darius speakers, Technics speakers, Canon speakers, Bastanis Dragonfly Horns, REL Storm III sub, Target R1 speaker stands, Atacama Equinox.
I'm Allen.
You should get lots of adds now for GLUE
I use a tube of wallpaper adhesive. It's for little bits and seems that won't stay down. Think it was pollycell
Sent from my G8341 using Tapatalk
I'm Mark.
If it's bare card to bare card then wood glue or pva, if it's glossy then superglue - but you may not be able to get the record out afterwards!
