If the speakers wobble when you're walking near them, it's the floor that needs sorting.
Is the underfloor space accessible? And can you fit under it? The floor joists probably rest on small brick walls at intervals, and they can move/settle over the decades. This can lead to the joists "hovering" over their supports in places. By using a car jack to slightly lift the joist, and then shimming into the space with something hard and permanent (not wood, pieces of slate are ideal) then lowering the joist back will sort things for a few more decades. Shimming it too much though will make other joists hover though, so don't go mad with it!
Sounds like a bit of a faff, but really it's quite simple. If I can do it (and I have) then anyone can
