I'm Tony.
I'm Tony.
Not sure how helpful this will be but I gave up on picoreplayer and just installed max2play and during set up it asked me what set up I was using. I checked boss dac and away it went working 1st time.
I never figured it out but there must be a setting for the boss in picoreplayer?
VPI Scout 1.1, Hana ML, Vanderveen MC10 SUT, WAD Phono3, Rpi3B+/Digione Signature, Xiang Sheng DAC-01, WAD KiT6550 and Reiver Edingdale SR
I'm Tony.
The same way that picoreplayer is done.
Download the max2play img from their website and burn it to a SD using win32disc and then put the SD in the rpi.
Search for the ip address of the rpi using adavanced ip scanner.
Type the IP addy into a PC browser and up comes max2play page ready to take you through the process.
Simples
m2p looks good to use. pretty much a squeezelite system
Ok may try that but just had a thought. Could it be they way i have the combined unit powered. Without the isolator i powered the RP and Boss with separate supplies. But ive just realised the Isolator has a USB C power supply - so I am guessing i should be powering up the RP via the Isolator?? I cant check as i only have one USB C power cable !!
Anyone have any thoughts - does that make sense?
I'm Tony.
I went through all that when I couldn't get picoreplayer to output. I suspect pcp has an output setting for the Boss that I didn't find.
Anyway, I would just set up the rpi-isolator-Boss with all jumpers in place and then log into pcp and look for the boss dac setting. It must be in the player settings somewhere.
Power up by inputting power to rpi and Boss DAC with nothing connected to the isolater
there will be, yes... everything should improve.. maybe as much as 100 hrs, but certainly 20. well done
