If so, what App are you using?
Source
SW1X USB II
SW1X DAC III Special
Audiolab 6000 CDT transport
Amps
Speakers
BK Electronics XLS400FF Sub.
Cabling
Headphones
Haven't been measuring speakers, just for interest.
Spectroid on android.
Source
SW1X USB II
Amps
Speakers
Cabling
Headphones
Speaker meter is available for iOS, don't know if this will suit your requirements, there are others that may be better but you have to pay for them.
Gary
I use “Spectrum” available free from the App Store.
I also use “Decibel X” for volume measurement.
For my basic needs these work just fine.
Thanks guys I will have a look at both Spectrum and Speaker Meter.
Source
SW1X USB II
Amps
Speakers
Cabling
Headphones
I'm William.
Hi Guys
An interesting site I came across is https://www.audiocheck.net/. It’s an application that runs through a browser, there’s even a test to check your browser. It has lots of interesting things including a hearing test, and best of all its all free. I used the hearing test on my iPad, and then when I did it again through the pc wired through the system, I got the same result disite the difference in quality.
Anyway it’s there to play with.
Hope it helps
I'm Allen.
Would the microphone be good enough on a iPad ???
Source
SW1X USB II
Amps
Speakers
Cabling
Headphones
