I'm Deleted.
How ‘massive’ the noise generated is directly depends on how long the connecting cable is - or aerial as it is otherwise known. The more cables you attach the more aerials are created.
Account Deleted
That's what I was saying before. Get the level of noise up to the point where it is audible as 'improved soundstage' and off you go. But the box itself doesn't actually do anything, the wire inside it you are plugging into is just an extension of the aerial. If there is a genuine tweak here then it can be done a lot cheaper.
Have anyone of you tried the damn box instead of trying to make some unfounded theories?
Mark. & Martin comments could be applied to everything related to hifi ... cables, tt, CD players, ...
Turntable: Sony TTS-8000 ;Tonearm: Phonomac AT-1010 Mk6; Cartridges: SPU GTE / VDH Colibri XGP / Decca SC4E rebuilt by ESCO with Paratrace; Phono Stage: Shindo; SUT: Bob's Device Cinemag 1131; Pre Amp: Shindo Monbrison; Power Amp: Shindo WE 300B Limited; Speakers: Shindo Lafite / Auditorium23 Solovox; CD Player: EastSound CD-E5 / Sony PS1; Cables: Yannis 423.5; Yannis 223.5; VDH The First Ultimate; Totem Sinew; Audio Tekne ARSP-500 / Auditorium 23.
The theorising is based on the independent measurements of one such device I posted earlier on in the thread. Granted they are just theories, not facts but they are not unfounded. IMO if the device does have a real effect then what has been suggested is likely, although not certainly, how it does it.
I'm brian.
Yep, everyone s deriding the thing without even hearing one. And the people that have tried it like it !
Scientologists use a similar box I think, or is that something else? Anyway, I'm sure they're convinced about whatever it is their box does.
