Music is just multiple tones though. It isn't fundamentally different from a single tone.
I would have preferred it if archimago had tested it exactly as its intended to be used in a system, testing it any other way tells you nothing about how it performs in a system.
that said, if one further read through that thread you'll see he tested it with just wire and also same wire and entreq box and the noise was worse with the box attached to the wire. So wire acts as an aerial and so does the box.
All it does is add a source of low level broadband noise.
Which could be perceived as an increase in sound quality. Trouble is you can't easily test for that as Entreq claim the effect takes time to come on and then fades away over time even after you've removed the gadget. Which is convenient. So you have to try it for yourself and see, knowing the thing is in there, and then try to detect an effect which is going to gradually come over time.
I mean if the effect is very obvious then no problemo. But I gather it is not, it seems to be a very subtle enhancement of soundstage and image placement, going by the testimonials. I'm not sure I would even notice it. especially with the sort of music I usually play.
I'm Dennis.
I think that scientific methodology should be adhered to; DB tests.
We should also avoid sophism and non sequiturs.
Not according to Bernard:
Be most obvious 'covering of one's back' by Entreq is their disclaimer that their Grounding Boxes may not benefit some systems.Originally Posted by Berni217
So we have the usual dichotomy with these devices: the sceptics think them absurd and will not try them; the believers will say if they have not been tried then one cannot comment. Even if the sceptical try one and hear no difference whatsoever, then the protagonists will say their system is not resolving enough, or that the listener's hearing is inadequate ..... And so it goes on.
I'm Stephen.
Macca, next they'll be claiming that the reason it takes time to work is because the box filling takes time to charge itself up to working level due to the small currents running through the ground. (current, via a single wire, with no return ?)
They don't need to say anything it would seem. Entreq happily sent the box in to be measured so clearly they are not bothered what that turned up -I suppose as it's not going to make a blind bit of difference to someone who has heard the effect and decided they want one.
I'm Dennis.
' Simply replace the wooden clamp on your entreq box with this and you will hear an improvement in soundstage, detail and placement around vocals and instruments, bass is tighter and the overall effect is a far more engaging sound.'
Not difficult to imagine a hypnotist swinging a pendulum in front of the buyer's eyes whilst saying this. :-)
I can speak of the difference the Coherent RTZ grounding box makes. No idea of the others.
My measuring implements - ears and brain
Massive improvement in all areas including lower noise floor, yes lower.
Putting CD after CD on and amazed at what is being revealed.
Currently seated and struggling to leave the music.
Wanna listen ?
North West Surrey is where I is.
Mike
