Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 60
Thread: Does Your Wife/Partner Like Bass?
  1. #21
    Probably fair to say all speakers are a compromise, the point being that we enjoy the music they make, however wrong others may feel it is.
    Thankfully we have accommodating ears and brains that smooth out many of the obvious potholes, and love for various musics that impel us to the diverse compromises that make it seem 'right' to us.
    Boomy bass is a room issue overwhelmingly, so saying plodding bass is a ported speaker speciality. Yet with classical music it is, to me, a better compromise at socially acceptable volumes than the allegedly more accurate alternative.
    So who can tell me which is more 'accurate' to the original musical event given the choice between a dipole at 87dB in room, a ported box speaker at 95db, or a massive sealed box at 110dB, all with the same music playing? *
    *excluding those who think louder is by definition better
  2. #22
    I'm Justin.
    Wise not to generalise too much regarding ports. I'd probably agree that at the budget, small speaker level I'd take a sealed box most of the time. But beyond that all bets are off. These JBLs are easily the best passive speaker I've ever heard and the ports are big enough for a badger to get into them:
    They are excellent. The 4367 is better than their much more expensive models. Confusing.
    I might get a pair. No really. I might. If I move house next year and the room demands them.
    EDIT: let's face it though. They look shit.
  3. #23
    I'm Justin.
    Anyway, no, she hated my Martin Logan Descent, now long gone.
    The issue appears to be long throw woofers. My main speakers extend to 21 Hz at +/- 0DB in room. That doesn't bother her even with tracks with copious amounts of bass. Why? Very high surface area woofer with low excursion.
    Punch deep holes in the air with a long throw sub and she soon complains.
    Long throw woofers punch air that is truly room/car 'wall' penetrating.
    Bad news for others.
  4. #24
    Default Yes
    She frequently says 'it is really great that instead of just noise I can now follow the tune in the bass' but she is a bit weird as she loves listening to my systems(s) !!!
    Nick
    UK - Technics SP10, EPA 500, AT33SA - Roonserver on i5 NUC running Windows 10 Pro - Devialet 1000 PRO CI - Magico S5 - Finite Elemente Wall Shelf
    Spain - Roonserver on i7 NUC running Windows 10 Pro - Devialet D250 Pro CI - Ergo IX
  5. #25
    This article is pretty good for explaining what is going on, worth reading the whole thing. https://www.stereophile.com/content/...6WfYbZ6cVqU.99
    Traditionally, reflex systems have been described as "boomy," yet are often found to provide less power in the low bass than the specifications suggest. Those specifications were based on test-chamber measurements and a rated -3dB rolloff in the bass. However, the important factor turns out to be what happens below rolloff.
    The aural sensitivity to changes at low frequencies is great, and we have room gain adding to the available response, helping to counteract the rolloff. A well-damped sealed-box system can have a desirably slow rolloff rate significantly complemented by room gain, thus extending the overall useful response. Below box resonance, the output from a bass-reflex system usually falls rapidly, too quickly for the room boundaries to help out; no low bass is heard.
    In addition, the reflex system is likely to have a sharper, squarer response "cover" at rolloff; mild room gain at this frequency can easily turn the corner into an audible lump---the notorious "boom."
  6. #26
    I'm Gary.
    Mines likes her's deep and firm...
    (Sorry! But it was only a matter of time before someone went there...)
    AC POWER
    AMPS
    SPEAKERS
    Wharfedale Evo 4.4
    DAC
    TURNTABLE
    PHONOSTAGE
    DIGITAL
    MUSIC PLAYBACK
    Ipad Roon Remote.
    SPEAKER CABLES
    INTERCONNECTS
  7. #27
    I'm gone.
    Quote Originally Posted by Hypnotist View Post
    Glad I'm not the only one then, my wife likes Tinny Sounds - period
    My Mrs definitely couldn't be having with your bk200sub.
  8. #28
    I'm Shaun.
    Yeah my other half Sue loves the addition of the new subwoofer. She loves the electronic music as well but prefers stuff like the Mahavishnu Orchestra. Not my kind of thing
  9. #29
    Very true. Especially if you are listening to a recording where the bass guitar was recorded direct into the desk. I.e most of them.
    I'm talking a local pub playing jazz with an unamplified brass and drum kit! Apologies for not explaining it properly. Back in the summer, our 'carnival procession' had a samba band, a Scots-pipe 'band' and a brass band with big bass drum
    Now, not the same as a recorded album I grant you, but to FEEL the pressure of the bass and percussion brought it all back when I had speakers able to so this in-room properly. The huge (by domestic standards) PMC fenestria's do it quite well too - and these things are bloody passive as well - eek!
    Most domestic speakers really don't 'do' bass properly and I remain convinced really that you need large drivers to even begin to do this, no matter how these drivers are loaded. sadly, 12" or larger bass units aren't domestically acceptable in 99% of homes and having a separate listening room or rooms is so damned unsociable and 'solitary' in my opinion. Marco once claimed his situation worked as his better half would join him for music sessions, but it doesn't work that way in every case and certainly not mine
  10. #30
    Agree with you about the speakers - to get the depth and the slam you need to move a lot of air very quickly. But with the live band situation you have to take into account that the act of recording it will diminish some of the bass impact you hear and feel live. A recording is unavoidably a degredation of the live event. And high fidelity (in the strictest sense of the term) is trying to be true to the recording of the live event, not the live event itself.
