Just had a read through a recent thread on AOS about buying floor standers and it struck a chord with me, certainly at present anyway.
I currently have a lovely pair of Impulse H2's, a lovely design of horn loaded speaker from the early 90's. Not perfect but they give a lovely musical rendition. However they are a reasonable size! 1200mm * 300mm *500m, quite a big footprint, certainly in a modern average house lounge, and even I have to admit they can be a bit dominating. So here's the rub, recently I have heard those magic words, "How long are you going to keep those speakers for?", and "There must be smaller ones that sound as good" so we get where this is going. So far I have resisted these utterances, but I suspect the mutterings will gradually increase to the point of frustration.
So where do I go to from here? I used to own a pair of Dali Ikon 6, very nice but not as accurate or as musical IMO, but acceptable in size terms. Mid reasonable sized range floor standers will be accepted. The ARC's I own are lovely, very accurate and produce some wonderful low-mid to top, and even the bass is not bad, but the low end bass is as you would expect from a stand mount gets as low as it can around 50-55hz and then its gone.
So I am open to suggestions? I have some thoughts but I am certainly not up to date with speakers produced over the last 15 years, and there is so many to choose from it is bewildering.
