Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: 12bh7 in a Croft
    Quote Originally Posted by snowman_al View Post
    Not really the same thing...
    Plus the 6414 has limited anode (plate) volts of 200 max. Where you might fit a 12BH7 for a 6414, do not assume it works the other way.
    Alan
    I thought they where interchangeable? Did I read right 12BH7 anode is 450 v ?
    I am glad I have enough 6414 tubes to out last the amp, so I will never need to substitute.
    I used to get these as little as a fiver each NOS.
    Jeff :UBERTHREADKILLER
    I'm John.
    Default Valve terminology?
    Morning all
    When looking at NOS valves terms like "pinched plate", "oval plate" and "winged plate" are often used to describe anode appearance. Is there any online resource that explains what these, and other terms mean?
    Or feel free to chip in if you can enlighten me yourself
    No consistent use IMO. Usually pinched waist refers to the glass envelope of some 1950s valves that had a narrower middle, or more commonly a narrow band where it joins the base plate.
    Oval anode is just anode shape, easily visible. Other egs are ladder or ribbed plate, flat plate, winged plate, and these are constructional details that indicate which production type the valve belongs to. These changed within manufacturer, across factories sometimes, and manufacturers would balance demand by selling and buying rivals bits and pieces and complete valves and branding as their own.
    The details are treated fetishistically by some, truth be told the construction can make a difference to performance but so can many other more contingent factors like original performance of the individual tube, its usage history and lifetime stress, condition of getter flash, pins, and the circuit position it is used in.
    In valve regulation of a PSU I wouldn't sweat these details, just make sure it meets minimum manufacturers spec ( called NOS by some but actually a slightly different thing).
    Hope this helps
    Hope this helps
    And don't forget the coatings used on the Cathode - these secret formulas were also key and most of the best ones are probably illegal to make now.
