Results 1 to 6 of 6
Thread: cable run length?
    I'm Terry.
    Default cable run length?
    Hi Everyone
    I have a Ariston Audio RD40 turntable going into an Edwards Audio MM1 Phono stage.
    My question is this, does it matter about the long length of the cable run that goes into my amp?
    The SME 3009 arm goes straight into the phono stage with short cables of about 14 inches long, but then after this the cables going into the amp are probably about 12 feet long.
    Merry Christmas everyone !!
    I'm Adrian.
    Quote Originally Posted by Terry View Post
    Hi Everyone
    If I remember this correctly the longer the cables are the greater the impedance and this will have some effect. The cable from TT to Phono stage I believe it is important to keep the impedance as matched as possible to the cartridge or lower than it. Once again the length of the cable from phono to power amp is important but because of the higher voltage you should be able to get away with longer lengths although 12 feet seems a bit extreme. I'm sure someone on here with more electronics knowledge than me can give you a detailed explanation. By the way this quality/conductive properties of the cable have and impact as well.
    I'm Gary.
    I would have thought something with low capacitance like this would give sonic benefits.
    http://www.van-damme.com/vandamme_pr...-956fdb7d-3ca2
    Gary
    I'm Timothy.
    I suppose that if you are not experiencing any noise issues and all sounds well, you should be good to go. Generally the shorter IC within reason, the better I would think, but sometimes it just isn’t practical or the situation doesn’t lend itself to shorter.
    Holbo TT-Nag 110-Croft phono/Innuos Zen MK2/LinnenberG Telemann DAC-Preamp/LinnenberG Allegro monoblocs/Duevel Venus/LinnenberG Maestro SE-Senn. 660S DH Labs cabling
    Croft Series 7 amps, WLM La Scala, Naim Uniti1, Naim Nait XS3, Naim ND5XS2, Guru Junior
    Any very low capacitance, good quality cable will do. Your phono stage will have a low output impedance and the amplifier will have a high input impedance, so the resistance of the adjoining cable will only slightly affect the sensitivity. Regardless of length, the transmission loss will be < 0.1dB.
    Just make sure the cable capacitance is as low as possible, in order to prevent the high frequency roll-off intruding into the audio band.
    12' ( ~ 4 metre) may sound a long length, but I use 12m long interconnects between my preamp and monoblock poweramps (they are fully balanced however)
    I'm Terry.
    Thank you everyone, put my mind to rest now !
