Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: S/PDIF vs USB
    I'm John.
    Default S/PDIF vs USB
    After enjoying the FLAC Files played from the Laptop, through a Bluetooth Speaker.
    I am now getting curious about hearing the Laptop and FLAC Files played through the main system.
    My DAC has a USB and COAX Input, so I believe I can play the FLAC Files straight into the DAC using a USB Cable.
    Is anybody using the USB Cable option as a interface ?.
    How is USB Cable rated as a interface, against the more common mentioned S/PDIF interface ?
    Are there any recommendations of Brands to be considered ?
    This will be my first venture into digital replay beyond CDP/DAC with a Mapleshade COAX Cable interface.
    Another experience to be ventured into, during the long dark evenings.
    I'm Marcus.
    I use USB, and I think a number of other forum members do as well.
    The 'better or not' depends on the particular implementation of a given dac, for me, USB sounded the best.
    I tried a few different USB cables out, from the cheapo type you use with a printer, a Belkin and tested a few others out at a dealer.
    I settled on the Chord C-Line, as I needed 3M, and it was the best I could get for my budget at the time, and certainly a worthwhile improvement against bog standard or Belkin.
    You need to try out with your particular kit, some people never hear a difference.
    Furutech/Studio Connections power cables and connectors-> Modded Marantz CD63SE or PC ->Schiit Bifrost MB -> RFC Venus Interconnect ->Marantz PM-7200-> TQ Black II Speaker Cable->Focal Aria 906
    I'm Clive.
    Just goes to show we all have our own opinions. I have just spent the afternoon comparing sp/dif & usb from my Aries G1 to my Qutest dac. With both connected and swapping between the two listening for about 20 min each and doing the exercise 3 times, I came to the conclusion that sp/dif sounded better to my ears.
    Im not saying that this is a definitive conclusion, just mine. It maybe well worth others trying the test.
    SOURCE:Auralic Aries G1, OPPO UDP-205 BluRay, SkyQ, Technics SL1210M5G/Achromat/MN Bearing/Isonoes with Boots/Origin Live Encounter Mk3A/Ortofon Cadenza Black or Hana SL or AT33PTG/II. PS Audio NuWave Phono Converter
    DAC: Chord Qutest, Chord Mojo/Poly
    AMPLIFIER:Bryston BP17-3 Pre & Bryston 4B3 Power
    SPEAKERS: Spendor D7.
    HEADPHONES OPPO PM-1 with Atlas Zeno cable, B&W C5 v2
    CABLES: Analogue: Speaker - Chord Signature. Interconnect - Atlas Mavros XLR x2, Atlas Mavros Ultra, Chord Indigo Plus XLR.
    Digital: Atlas Mavros Ultra x2, Atlas USB, Chord Optichord.
    Mains: Chord Power Chord x2, Black Rhodium Libra/MK/Shurter or Wattgate x4, IsoTek Orion 6 way, Sounds Fantastic 6way Mains Blocks.
    STORAGE Synology DS216J NAS with 2 x 3Tb WD Red hard-drives.
    TV LG55B7 OLED
    I'm Neil.
    Everything comes down to implementation and in some cases Coax is better than USB, but in others USB is better.
    Regards Neil
    System 1 (Living Room) : Vinyl: AMG Giro Turntable, AMG Giro Reference PSU, AMG 9W2 Tonearm, AMG Reference Armcable, Air Tight PC3 MC Cartridge PhonoStage: Passlabs Xono Digital: Esoteric P5 SACD Transport and Esoteric P 5 DAC, Sony HAP Z1es Digital File Player + Audioquest Jitter Bug, Computer Audio: Veracity Audio Mystra DAC + HP laptop + iFi Audio i Power, Wireworld Starlight USB + Audioquest Jitter Bug Tuner:Kenwood KT 7020 Cassette Tape: Nakamichi CR5e Amplification: Pre-Amplifier Meridian G02 Power-Amplifier Meridian G56 Speakers: Anthony Gallo Reference 3.1 Audio Cabling: Signal - Atlas Mavros, Audience AU24 Speaker - Atlas Mavros. Mains Cabling: Audience AU24, Analysis Plus, TCI. Mains Distribution: Mark Grant Distribution Blocks, Mark Grant DC Blocker Equipment Tables: Target Audio B series + Track Audio Isolation Spikes Isolation/ Platforms: Bright Star Audio Isonodes, BASE 01, SSC Platforms.
    System 2 (Music Room) : Vinyl: Turntable 1 Loricraft Garrard 401 Turntable + SME 5 Tonearm, Graham IC70 Tonearm Cable + VDH MC10 cartridge Turntable 2 Modified Technics 1200 turntable + Triplannar 7 Tonearm + VDH Frog Gold Cartridge + Paul Hynes SR7 PSU Turntable 3 SME Model 20 Turntable + Graham Phantom Tonearm + Graham IC70 Tonearm Cable, Ortofon MC5200 Cartridge PhonoStage: Balanced Audio Technology VK10se Digital: Moon Andromeda CD Player, Toshiba 9500 DVD Audio Player Computer Audio: AMR DP777 DAC + Dell Laptop + iFi Audio i Power + JKenny JKSPIDIF + Wireworld Starlight USB Tuners: Kenwood 8300 Tuner, Revox B760 Tuner, Leak Troughline Tuner + EAR Stereo Decoder, Magnum Dynalab Signal Sleuth FM Amplifier ReelToReel Tape: Revox B77 mk 2, Revox A77 mk3, Sony TC-377 Cassette Tape: Nakamichi DR10 Headphone: Audio Valve RKV2 OTL Valve Headphone Amp, Headphones Grado GS 1000, Sennheiser 560 Ovation2, Sennheiser 410SL Pre-Amplifier: Balanced Audio Technology VK52se Power-Amplifier: Music Reference RM200 mk1 Speakers: Anthony Gallo Reference 3.5 Audio Cabling: Signal - Audience AU24, Kimber KCAG, Audio Note ANVs, Barry Hunt Cables Speaker - XLO Type 6. Mains Cabling: Audience AU24, TCI. Mains Distribution: Mark Grant and Russ Andrews Equipment Tables: Clear Light Audio Aspekt Tacks Isolation/Platform: SSC, Bright Star Audio Isonodes, Naim Frame Record Cleaner: Hanns Audio
    I might be wrong but as I understand it, at some point in the chain the file based output needs to be converted to S/PDIF for most dacs so there is a converter somewhere along the way. High end devices might have a high quality one built in at either end, but for average equipment anything built in is relatively low quality and you are better off getting an external converter from the USB out to the dac S/PDIF in. This often has other advantages in terms of better power supplies (if not driven off the usb power) and electrical isolation.
    I'm denis.
    I think that with the impossibility of a consensus about that usb versus spdif, all the crux of the matter depend of the implementation of the audio system and last but not least, i know that for sure, of the cleaning and filtering of the electrical grid and lines of the audio system...I use different mineral pieces of rock for that with a success astoundingly audible...It seems that the right minerals act like a kind of passive filtering device for the electro-magnetic field of the line and of the system and of the computer(router included)... Usually people laugh, and i usually does not talk about this anymore...But this forum is always civilized and if my remarks can make some curious spirit to try some experiment of his own with minerals he will be surprized and i will be pleased... It is difficult to be silent about that extraordinary case, and the results are so revolutionary that i dont call that a "tweaks" anymore...By the way i use s-pdif..
    Happy new year to all of you...
    I'm John.
    A year ago, with much lesser reading and philosophies learned.
    My thoughts on such a suggestion, that to place different minerals around a HiFi System, would have caused huge amusement, and in keeping with the Thread, "I would have thought somebodies taking the S/PDIF here" .
    Today though things are different, I suppose a analogy would be, I have become the flea, that scaled the hair, leaving behind the security of lower environment, to see what the world outside is offering.
    The idea of processing materials such as wire, to re-orientate their molecular structure following manufacture processes is acceptable, and seen as a design that could produce results that surpass a standard process of producing wire.
    The idea of Natural Dielectric Sheathing, Isolating Cable from contacting synthetic materials, are practices I do not see as unnecessary.
    I see them as designs to be tried, when a system is perceived as being at the end point, trying these designs at the interfaces of devices may just eek out the last bit of synergy.
    If your use of crystals has been perceived as a method to eek out that last bit of synergy, then I am pleased you have discovered it.
    It might be cheaper than uber expensive cable.
    For the curious types, who might be enticed to give it a go,
    What crystals types do you use ? How large are the crystals used ? Where do you suggest placing them ?
    As a response to the answers offered to my original post, it is now my view that I will need a Eitr interface between Laptop and DAC.
    Laptop>USB Cable>Eitr > Digital Coax> DAC.
    A device to replace the Laptop will be chosen in 2019, when I have more understanding, at present,
    a Kingdel i7 NUC, at less than $400 has a attraction.
    I'm Edward.
    What is Eitr?
    By the way in addition to optimising your cables (and philosophies?) also focus on optimising the OS on your computer. Lots to do there especially if you are using Windows. Worthwhile improvements to be had. Maybe you already did.
    Source: Tidal/Roon
    DAC: Metrum HEX, Chevron Paradox
    Amp: Sugden Masterclass 2018 spec, Radford Revival STA25 V,
    Speakers: Tannoy Eaton, Kudos Cardea
    What would u do Ed, pc wise?
    Grant ....
    OPPO BDP-103D DARBEE - JBE SERIES 3/B&O SP1/PROJECT PHONOBOX DS2 USB - QUAD VENA 2/TWIN PRO MONOBLOCK POWER AMPLIFIERS - XS VALVE DAC - AVANTREE OASIS PLUS + LEAF HD BLUETOOTHS - OPPO PM-3 PLANAR +NURAPHONE HEADPHONES - ZBOOK/WIN10 PRO/AUDIRVANA 3 PLUS/TIDAL - SMSL M6 MINIDAC - RPI 3 DIGIONE/VOLUMIO - FULL RANGE TWIN TELEFUNKEN MAIN SPKRS/Q ACOUSTIC BT3 ACTIVES & CANTON SUB - P.INSPIRED MAINS REGENERATED.
    **Men are not punished for their sins, but by them**
    I'm AMusicFanNotAnAudiophile.
    Quote Originally Posted by Edwardlon View Post
    What is Eitr?
    Good question - some folk seem to think everyone is telepathic
    Could be one of these http://www.schiit.com/products/eitr
    Chris
    Common sense isn't anymore!
