Results 1 to 4 of 4
Thread: Pioneer pd-s703 remote.
    Default Pioneer pd-s703 remote.
    Hi i am having trouble finding a remote for my pioneer pd-s703 cd player. The number of the remote required is CU-PD070, however i have located a pioneer remote Number CU-PD081 it looks identical to the one i am looking for do you think it might work with my pioneer.
    Regards James.
    As an alternative might a multi remote work ?
    EG Logitech Harmony
    Mike
    I think you may find that any Pioneer CD player remote control may work OK. I have three different ones and they each work with my PD-S505 Precision.
    Thanks Guy's
