Results 1 to 10 of 10
Thread: Any good DAC headphone amps out there?
    I'm inactive.
    Default Any good DAC headphone amps out there?
    Have been looking at DAC headphone amps for a while as a solution to a particular set up problem.
    Quite interested (price wise) in offerings from Douk Audio and Topping but a bit wary given some conflicting user reviews re. reliability.
    Anyone have experience of their products they'd like to share (or other suggestions)?
    Been using an smsl m6 for quite a while with no issue. Sounds pretty good as well
    I'm gone.
    I use a Topping VX1 - looks great, sounds good.
    Inputs are USB for digital and L/R RCA for analog.
    It's also a 25wpc integrated amp. I use the latter to drive Stax SR3 electrostatics and the headphone jack for Philips Fidelio X2.
    Very pleased with it, had it a year or so with no issues.
    I'm inactive.
    Thanks for the suggestions chaps - appreciated
    Unfortunately I should have said that USB input is not an option - I only have SPDIF output options to use for this set up.
    Also keen to hear from anyone who has had bad experiences with Douk/Topping/SMSL devices. particularly if this involves sending back to China for replacement/repair.
    m6 has all three inputs. not tried coax tbh but used the other 2.. also has rca out if wanted. only thing is getting used to the multifunction switch/joystick button. once mastered it works very well tho. mine is on 8 hrs a day every day and has been flawless. with my planar's its super but was also great with my a technica's
    I'm inactive.
    So it has - sorry Grant.... must've done a dodgy Goggle search first time around
    Looks very smart for the money too. Also good to hear the toggle works OK, looked a bit off-putting (once I found the right one on Amazon...)
    Will add it to my list
    I'm gone.
    With regard to Chinese gear reliability, the only issues I can recall having was with several XiangSheng DAC-01A DAC/headphone amps. Great sound but prone to partial failure ime, particularly individual inputs dieing.
    I have had several Topping and SMSL DACs/amps over the last few years and they have performed flawlessly.
    Are your headphones wearing a wimple?
    I'm gone.
    Ah, the Stax?
    I'm experimenting with various configurations of earpad.
    Current favourite is a pair with segments chopped out to make them more open.
    I'm inactive.
    Just to set the context - this is the set-up I want to use it for:
    The Vena does have a headphone output but I have a better result using either one the two analogue headphone amps i have (MF V-Can or modified Akafugu C-Moy).
    Problem is that the Vena doesn't have the 'tape-out' option I am used to with pre-amps and is limited to 'pre-out' controlled by the Vena volume in parallel with the speakers.
    What it does have is SPDIF out (coax or optical) which would be an ideal option if used with a DAC headphone amp.
    I could use the Saffire DAC for this but it's a bit of a faff in this particular set up and also doesn't behave itself if connected to the Mac at the same time as the Vena - also the onboard hp output on the Saffire is not great.
