I'm Drew.
The PS Audio P10 can be found on the PS Audio website, do a google search.
Ebay can be used to buy Pure 2mm silver & 3mm teflon tubing. Alternatively you can always look for jewellers supplies websites.
Otherwise, which other bits do you links for?
I'm Drew.
Thanks...Was just looking for the wire, will check out ebay... the PS Audio 10 is unfortunately WAY beyond my means!
