Results 1 to 10 of 17
Thread: Braun shavers
    Default Braun shavers
    For many years I have been using Braun shavers and the past 7 years a Braun Series 7. Now, I have always been pleased with the performance of Braun but the past two years or so, I am finding that the cutters last only a few weeks before needing to be changed.
    In the past, the cutters remained sharp and gave a good, clean shave for a couple of years before needing to be changed. Indeed, the shaver has a warning light to let you know the cutters have been going for 18 months and should be replaced. Lately, I find that the cutters are sharp for only a couple of months at most and then need replacing. I have bought cutters complete with foil from Shavers UK and the last two from Boots - reputable companies and the cutters should be legitimate and not cheap knock offs.
    The latest cutter/foil replacement I started to use at the beginning of October and from a couple of weeks ago is removing so little of my stubble that I feel I need a shave right after I have finished shaving. I can see by how little stubble is banged out in the sink, that it is hardly removing anything.
    Anyone have the same problem or have any advice because these cutters are expensive.
    I read this a few weeks ago... gives an idea as to why the blunt early sometimes
    https://www.shaverguide.co.uk/do-ele...vers-go-blunt/
    Had 1 replacement on my Series 7
    Took a punt on the cheapest on Ebay from South Korea
    Seems fine after about 6 months
    Mike
    I have four Braun shavers: one portable battery operated device; two dual voltage devices and a single voltage rechargeable device. The one I use regularly here in the UK is about twenty years old and is good as it has ever been. That's not to say I haven't had to replace the foil - I have, because with time and a lot of use the holes in the foil can break into one another, making shaving uncomfortable. But I have only had to do it twice.
    IMO, there is no excuse for the cutter head (and by that, I take it to mean the foil) to need replacing every couple of months. Sounds like Braun are doing a bit of 'cost cutting'.
    The whole point of 'dry shaving' is that it is quick and convenient. If you are going to have to go to the bother of preparing the skin with hot water or some sort of pre-shave oil, then you may as well go the whole hog and wet shave - which will give you a closer shave than using an electric razor.
    Son has been using his series 7 for a year and says it's good as new
    I can't see how I can possibly do anything wrong. As I said, I've had this Series 7 for several years with no problems at all, it's just the cutters and foil I have bought the past two years which wear out in a few weeks. I'm not Desperate Dan with a tough beard, just normal stubble.
    Is there an adjustment I'm missing on the shaver itself or are Braun making inferior cutters ?
    Suspect the latter as a cost saving exercise.
    Might be a cheap Chinese copy new blades. Ive not got to this stage yet. Nightmare scenario
    I wondered if they wre cheap Chinese copies, so I ordered from Boots who would source them properly but they last only a couple of months at best.
    Are the Braun shavers now made in China? It wouldn't surprise me: my partner just bought herself a set of Sony headphones that are made in China. Not that it should make a difference if Braun have full control over the sourcing of materials, the construction and quality control.
    All of mine were made in Germany.
