Originally Posted by
Sherwood
Buy it with the Dorado power supply. This, in my opinion, has a bigger impact on SQ than a linear power supply. Stanley will supply the appropriate power supply if you buy the Dorado at the same time.
+1 the Dorado is very good provided you set it with 15V output. At less than €100 the Dorado is far cheaper (and smaller) than a good linear supply
Cheers
Alastair
RPI4/PI2AES running PiCorePlayer/LMS-> AQ Carbon AES -> Topping D90 DAC-> Khozomo Passive Pre-Amp -> 4x Temple Audio Monoblocks powered by 2xLiFePO batteries->Van Damme Black Bi-Wired to B&W 804 Nautilus and Sommer Carbokab 225 Interconnects
