I'm gone.
Doesn't work from my phone either, **** this!!!
Yup you have to search initially for cca's own WiFi then enter your WiFi no etc. Just chill and try a few times. It's usually something simple.
We've all gone through the initial hair pulling mate
So, Google home app says 'no eligible devices for app install'.
have you searched for cca's wifi set up address in phones list of wifi's in phone settings
Dantes inferno needs to be updated to accommodate another circle of hell.
its a learning circle alas. its easier if someone can come in and show you. if you think cca is difficult then try a rpi. although they are much easier now too.
pity you werent local, i would have popped over and shown you mate.
first is finding the cca's transmission in your list of wifi's on phone. if it doesnt show switch it off and then start again. it only puts it out for so long.connect your phone to it and then go to the app again and it will then ask you to put in your home wifi
Might ask the girlfriend when she's finished making me chicken soup, got a chest infection.
