Page 2 of 21 FirstFirst 123412 ... LastLast
Results 11 to 20 of 209
Thread: Chromecast Audio
    I finally got RPi + Kali reclocker outputting using I2S into my Najda DSP XO DAC properly.
    With good power clean Lan RPi has the measure of Chromecast Audio using Spotify on both.
    I can honestly say, it's sounding so good I won't be continuing with Tidal..
    There are more setting to tweak in PuTTY too..
    Sent from my Moto G (5) using Tapatalk
    I'm Gary.
    Not convinced by a clean power supply to an Internet based source, I think the battery in my phone is fairly clean but can't speak for the miles of cabling before my router
    Marantz CD63 KI Signature
    Project Debut II
    Pioneer A656 Reference
    Epos M5s
    Atacama Stands
    Maplin speaker cable cos I can't hear a difference
    Various interconnects as above
    Quote Originally Posted by Gaz View Post
    I look at it this way.
    The cabling to your router is handled by your ISP and the protocols used if high speed and stable are quite capable of supplying the bits reliably (with necessary error correction automatically done seemlessly), enough for HD TV, streaming music etc.. having a router near your HiFi on the same ring main with a switching mode PSU spitting noise out noise that other gear and the router had to deal with is a good thing to cut out.
    Going forwards I'm sure we'll see more and more audiophile routers as we understand more about streaming. If it measures better and sounds better it's worth doing..
    As I've done more of these things the happier I am with the sound..
    Easy to go back and try without them to confirm (which I've done).
    I'm Gary.
    Then we'll need to fill our rooms with audiophile air so that wireless streaming isn't compromised by dirty air.
    Project Debut II
    Epos M5s
    Atacama Stands
    I'm Gary.
    Well I took Gary's advice and got a Chromecast Audio yesterday and must say it's bloody impressive.
    All I was using before was an old Galaxy S6 plugged into my amp via a headphone to RCA lead, the difference in sound is incredible.
    Thanks for the recommendation
    Pleased your happy with it.
    Did you set the SQ to the highest in Google Home App?
    If or when you have a DAC you can run an optical cable from the CCA to DAC and get even better performance.
    Gary
    I believe ionising air filters are used by some. Possibly more in the US. I seem to recall seeing something about this, maybe targeted at reducing vinyl static though.
    fancy one for coming summer, but a decent sized one isn't cheap
    Air quality is bordering audiofool
    It would be more the movement of air due to sound waves than radio though.
    Perhaps the London smogs didn't sound great
    Gary. Please put a recognisable location in your profile. Thanks.
    Sounds like someone from ZZ9 plural Z alpha is going to be Terminated.
    Is it obligatory to have a recognisable earthly address?
    Dave
