We'll have to disagree on this one Jamie.
Because the way my brain works is that if I have wood of some kind that is dull and very dry, then give a treatment, application, whatever, that treatment be it a wood oil or wax of some kind then for me that treatment has done something.
The wood looks better, in some cases this applying or treating can prevent cracking and so on.
Wood absorbs the stuf you put on it, hence some woodworkers will leave a treatment on for a good while for it to 'soak in' as they say.
I dont see it as you put it that it isnt doing anything other than putting a coating on it.
Finished wood might be a bit different in some cases but even then, a really good real wood veneer as is on a lot of good speakers, benefits with the occasional wipe and rub of a good wood oil type application.
Thats defo what I see in my experience and I would say the wood is nourished in a sense, I totally see why they use the term.
My System:
CDP - Pioneer PD-91
