Having purchased a allo digione recently I was about to pull the trigger on a cheapo linear psu for it but this got me thinking about what else could I use with similar or possibly even better results.
If this new psu could also power my other non psu inclusive components (amptastic mini-1 and minix) then all the better. The digione and minix run at 5v so these would require a buck or step down converter and these were picked up cheaply online.
Initially thought of a car battery but after some investigation I've settled on a Deep Cycle Leisure Battery (SuperBatt LH110) usually used for caravans or boats etc.. It's a big old beast so won't suit everyone (36cm wide and 22kg) Luckily the low height helps hide itself behind my cabinet.
I was going take a direct feed from the battery to each component but the minix and the digione don't have on/off switches so I fabricated a panel with 4 switches and a voltometer and I screwed this to the inside of my cabinet so it's hidden when my the doors are closed.
The mini-1 has it's own on/off switch so I've connected this directly to the battery with a inline fuse as added protection.
Sounds really good so far but only had a few hours worth of listening. Need to put the though it's paces now.
Sent from my SM-G930F using Tapatalk
