384KHz with SEG over USB?
I have been playing with upsampling to 192Khz in picoreplayer, which sounds very good and uses only a few percent of the CPU. This is over a coax link to the Caiman SEG. I wanted to try-out 384Khz but I have read the SPDIF output from the Allo Digione (and in general?) is limited to 192KHz. I reconfigured picoreplayer to use USB out put. That works fine to 192KHz but silence at 384KHz. I also tried feeding-in an upsampled WAV file - still slilence.
Is there an inherent limitation in the SEG (it is supposed to go up to double this) or could it be the USB cable I am using or am I simply doing something wrong?
Cheers
Alastair
RPI4/PI2AES running PiCorePlayer/LMS-> AQ Carbon AES -> Topping D90 DAC-> Khozomo Passive Pre-Amp -> 4x Temple Audio Monoblocks powered by 2xLiFePO batteries->Van Damme Black Bi-Wired to B&W 804 Nautilus and Sommer Carbokab 225 Interconnects
