Results 1 to 10 of 14
Thread: Pink Floyd Animals
    Default Pink Floyd Animals
    One of my Christmas vinyl choices will be Pink Floyd's 'Animals' on vinyl.
    Although the usual option would be to buy from Amazon, I see there are some terrible reviews for it there, citing muddy sound, warped discs and surface imperfections. One person bought a copy and it was so bad he had them send another - which was even worse.
    Has anyone experienced this, and do you think I would be better sending the lucky giver to an independent shop or HMV? At least this way I can return more easily. Or does anyone know of a particular pressing/issue to look for or avoid?
    Probably all going to come from same place and thus it's going to be same risk.
    The returns policy/ease of return, of the seller is most important.
    That was my thinking too Grant, so chances are I'll get it from somewhere local
    You wouldn't consider getting an original vinyl version second hand? It sold a lot, there are plenty of them out there.
    That is a sensible suggestion.
    I bought the original album new and I know mine is like new, because it's hardly been played as I didn't really like it much. I rate it as one of Floyd's weaker efforts and suspect others may have thought the same.
    It's actually my favourite later Floyd album possibly because it is the only one I haven't played to death.
    I'm Simon.
    My fav too.
    I'm AMusicFanNotAnAudiophile.
    In short, no!
    If it gets bought in a bricks and mortar store it needs to be returned to one, and they do not reimburse you for your travel costs.
    Amazon send you a returns label by email. You repack the LP in the packaging they originally provided, pop on the returns label, and take it to the Post Office or nominated returns store in your area.
    They will give you a receipt, and the refund (to the original purchaser) will occur within a day or three.
    I have purchased two of the last run of reissues (DSOTM & WYWH), and the pressing quality was excellent.
    I bought them in Sainsbury stores.
    Chris
    Common sense isn't anymore!
    Anita has bogged off into town armed with my music 'wish list' and all my wages (honestly, using my wages to pay for my Christmas pressies, I think I need to have a word)
    If she doesn't return with a copy of Animals, I'll go with Macca's and Geoff's suggestion and seek out a used original. I re-acquired DSOTM and WYWH in the last couple of years, and as I've posted before I found the recordings to somehow lack 'sparkle'. Though the jury's out whether that's more to do with my hearing being a bit shit these days.
    Thanks Chris, I was not aware of Amazon's returns policy (never had to use it). Good to know.
    Might also be that you listen to a lot more digital recordings these days. On a decent set up you can easily hear the difference. So when you go to play some of the old stuff the drop in fidelity can be a bit of a shock, unless it was a stellar quality analogue recording which neither of them were. I know that is how it is with me, anyway.
