When repanelled if the resistivity and tension is the same they sound the same. The opposite speaker panel had been repaired previously, early glue failure
Polyurethane, tried and tested
I'm Paul.
So while Simon is delivering another Paradise I'd better crack on with the Quad rescue.
3360 dots of Pu adhesive applied.
52 soldered connections and new closed cell foam buffers to grilles.
Socks up, lid on.
Next.
Going to collect this second one later tonight, then enjoy a weekend of new preamp and quads.
200 quid and a whiskey bribe, not a bad investment. That said mrdog must put 50 hours into them.
sounds like a lovely weekend ahead!
My System
John Wood KT88 Amp.
Paradise Phono Stage
Sony TTS-8000 Turntable.
PMAT-1010 MK6 Tonearm.
Ortofon Cadenza Bronze
Sony X555ES Cd Player
Yamaha NS1000m Speakers
Playing now, they sound ace, even thrown into the room
Ok, Now I have the measure of them, literally. I'm going to add some subs into the mix. I fancy on making some Gradient -a-like subs but with DSP on the plate amp. Nice little boxes, raise them up to a better listening height and fill in underneath.
Can you post the measurements for us Simon?
