Shim the denon, use with thorens and sme sell the rest, buy more records.
I'm John.
Thanks for the continued comments, and as several have suggested, I have already added a headshell shim to the 103 for additional mass.
Another recommendation for the Verdier Platine, similar to Charlie's. I have had mine for 14 years, although modified re bearing, feet, power supply and motor and arm boards and bolts etc. I can not really see why I would want to change it. The only other TT I would add to it would be Grand Prix Monaco; its elegance and technical virtuosity as well as it sound would be a great addition.
I’d sell the 125/SME (103 too) and keep the V15III to use with the 125/Rega while I search for a more dynamic cart like a top-level A-T mm.
Main system: Lenco L75, Thorens TD-125, Technics SL1700, ReVox A77 two-track 15 ips, Sony PS-1, Dell laptop, mxr, eq, Audio-Research LS-3, UREI 6150, DIY two-way speakers with Altec 802/811 & Goodmans 18” midwoofers.
Author of; “HIGH-END AUDIO on a BUDGET”
I'm Joe.
I had to add weighted shims to my RB300/DL-103 to get it to sound 'right'.
