OK learned ones
Whats the difference between a volume control and a attenuated volume control
I'm Allen.
OK learned ones
The only thing I can think of is an "attenuated" volume control does not reduce the volume to zero at its minimum setting. A bit like some balance controls only provide a 5 or 6dB adjustment range, rather than full left or right.
Where did you come across this term Al?
It could be a misprint of "attenuator".
I'm Allen.
Attenuate is a verb that means to make or become weaker. The versatile word attenuate denotes a weakening in amount, intensity, or value.
I have a Nikko pre amp that has " What I have refered to as attenuated , maybe the wrong word volume control " 32-detent attenuator IMG_3718.jpg ( Click on photo it gets bigger )
It starts at -70db lowests volume and rotates clockwise around to 0 highest volume in click stop graduations
Other amps I have just have ordinary volume controls no click stops just smooth rotation , no db scale either
I'm Mick.
HI Are you refering to a stepped attenuator?
If you are they use fixed value resistors (which give steps) compared, to a carbon track to adjust the signal level.
Some tracked potentiometers have a device to give stepped positions (Clicks), some just rotate and stop where you leave them.
Thats a very elegant way of describing a volume control!
Some have click-stops, some don’t and most of these are not stepped attenuators, but a normal pot with a knobbly metal ring behind them.
Most are labelled 0-10 or 0-[a number] but the Japanese had a spate of labelling them from minus infinity (or, as in your case, minus 70) up to 0 during the 80s. It’s all just styling and packaging and is largely irrelevant!
I'm Allen.
OK thanks , its just a volume control
soon
I have a stepped attenuator which is covered with resistors, looked to be a fiddly job to solder all those resistors in place.
