I'm Ian.
I'm Keith.
So what makes a hot rod and how is a turbo different. I have a hypnotize dcb1 black pcb built by a guy on DIYAudio. I bought it off Tom. It has Riken Ohms in the 220k and 1 meg positions and the four 220r are Shinkoh. The .22uf caps are now Jupiter copper foil in paper and wax. I first checked with Salas who confirmed these are the most important areas to improve. The rest are Dale, prp and Elna.
It has a TKD 601 pot that I am going to change to a Khozmo of similar.
I will take some internal shots when I figure out how to post pics to this site.
Garrard 401, Groovemaster 2, Arche headshell, Miyajima Shilabe, Paradise Phono amp,
Aqua La Voce dac
Salas DCB1
Najda active crossover and DSP.
Crown XLi 1500 x 2 bridged, Neurochrome Mod 86 monos, Guy Sergeant Hiraga Le Monstre,
DIY open baffle with 18" Fane Colossus XB, Beyma 12p80ND and Beyma TPL150H with BK XLS 400 sub.
Hi Keith,
The "Hot-Rodding" is in direct relation to how much juice you can get through the board.
Level 1 is 60mA (standard build)
Level 2 is 200mA (Mur860 upgrade)
Level 3 is 600mA (Mur860, 2.7ohm resistor change, 14w heat dissipation necessary)
Level 4 is 2A (Mur860, resistor change. Heat dissipation by fans and heat sinks)
The difference in clarity between 60mA and 200mA was significant. I'm glad I got it done for the new owner of my old one.
New build will explore a 1.2A version. Heat dissipation will be done via the Aluminium chassis and possibly a couple of 1" fans or similar. If that's not possible it will be 600mA
Hi All,
Just a bit of an update to the build with a few pics.
Checking if the layout works !!!
[IMG][/IMG]
Moved the fets off the board ( Firebottle ) suggestion to disperse heat through the
thick aluminum base and fit Khozmo Attenuator and Elma 6 way switch
[IMG][/IMG]
Will run at 600mA to settle in then will try at 1.2A using the huge heat-sinks for comparison
[IMG][/IMG]
Inputs wired using Olivers (Bigman80) Spotfire cable
I hope to have this finished soon but will wait until my wrist feels better before wiring the power.
S.
Turntable; Rega p8
Cartridge; Alpheta mc
Amplifier; Rega Elicit
Speakers; Rega Rx3
Nice I've just been notified of a package winging its way to me from Mr Teabag
Planning to start it over xmas when I have some time off.
