Regards
Brian
Amplifier : Sony TA FB740R
Speakers : Tannoy 637
Aye , the word's out mate
Regards
Brian
You need a linda lovelace socket
I'm Keith.
Cheers Oliver,
Will order from Toroidy I think.
2x12V, 100 VA. Does centre potting make any difference?
Might need to check here/get advice regarding wiring up the tails. Mine has red-black, 15V 40 VA and yellow-orange, 15V 40 VA. The connections onto the PCB looking from the input end have black left, yellow right and the red and orange to the middle.
KR
Keith.
Garrard 401, Groovemaster 2, Arche headshell, Miyajima Shilabe, Paradise Phono amp,
Aqua La Voce dac
Salas DCB1
Najda active crossover and DSP.
Crown XLi 1500 x 2 bridged, Neurochrome Mod 86 monos, Guy Sergeant Hiraga Le Monstre,
DIY open baffle with 18" Fane Colossus XB, Beyma 12p80ND and Beyma TPL150H with BK XLS 400 sub.
Keith,
The colours of the wires on the Toriody won't be the same so don't worry about that. We will help you figure it out when it gets to you. You'll need a multimeter to figure it out.
Mine is 100va 2x12v. That is sufficient up to 1.2A level.
I like the transformer to be resin filled as it helps with any vibration. I've just plugged my Traffo in and it's absolutely silent. That's why I go to Toriody.
