Page 12 of 26 FirstFirst ... 2101112131422 ... LastLast
Results 111 to 120 of 259
Thread: DCB1 TURBO BUILD @600Ma
  1. #111
    I'm Ian.
    Quote Originally Posted by STD305M View Post
    Like wise, I'll do a bit of googling too.
    Something I've not heard of but always open minded.
    Just out of curiosity where are they from ???
    S.
    https://diyaudiostore.com/products/whammy
  2. #112
    Listening to this Chinese relay preamp daily and it's pretty good for £100 but it suffers the same issues as all the other passive pres I've tried. It lacks pace.
    The Spotify interconnects are not a good match with my passive either so you might want to take that into account. I guess it might be to do with impedance.
  3. #113
    Bigman80 Guest
    Yep, tried some RG316u, Sommer and some Shark cable.
    SPOTFIRE are better than those. Shouldn't have to wait long mate, the pre is nearly finished!!!
  4. #114
    Quote Originally Posted by ijrussell View Post
    Hi Ian
    Thanks for the link
    Will have a look !!!!
    S.
    Turntable; Rega p8
    Cartridge; Alpheta mc
    Amplifier; Rega Elicit
    Speakers; Rega Rx3
  5. #115
    I'm Keith.
    Salas who designed the DC version of Nelson's B1 also has a preamp with gain if needed. I don't need the gain so the DCB1 suits me fine.
    So to get to 600 ma it just requires 4 rectifier be changed from MUR820 to MUR860 and 2 resistor values to be changed and the unit will operate with more juice without any further adjustment needed?
    Are the 4 rectifier the black ones across the end of the board next to the 4 caps? Any links for where to buy 4 x 860?
    Which 2 resistors need changing and to what value? Is it the 2 that run parallel to the short length of the board right next to the 4 caps. If so mine are Dale 10 R 6.5w (black Dale). Any close up pics of the resistors in question?
    Currently having a play with mine to rearrange in the case and try different attenuator. I have a TKD 601 in there and have some alternatives to try. TKD 2501, Alps Black Beauty, Khozmo Shunt, Acoustic Dimension and a DACT which is in there at the minute and is a huge step up over the TKD. My money is on the DACT or the Acoustic Dimension.
    Some nice looking builds there chaps!
    Keith.
    Garrard 401, Groovemaster 2, Arche headshell, Miyajima Shilabe, Paradise Phono amp,
    Aqua La Voce dac
    Salas DCB1
    Najda active crossover and DSP.
    Crown XLi 1500 x 2 bridged, Neurochrome Mod 86 monos, Guy Sergeant Hiraga Le Monstre,
    DIY open baffle with 18" Fane Colossus XB, Beyma 12p80ND and Beyma TPL150H with BK XLS 400 sub.
  6. #116
    Quote Originally Posted by keith1962 View Post
    Keith.
    Hi Kieth
    You need to use mur820 or 860, if you have MUR 820 already fitted they will be fine.
    the 2 resistor that need changing are just below the 4 power caps change to 1.8ohm 3watt, Approx...
    [IMG][/IMG]
    You can get MUR820 or 860 from ebay or Farnell
    Also change the 8 resistors around the relay to better quality such as Audio Note or similar if you
    want an increase in resolution.
    Make sure your Tx is big enough to cope.
    Steve...
    Turntable; Rega p8
    Speakers; Rega Rx3
  7. #117
    Altering to run at 600mA does involve lowering the value of the 2 resistors you mention.
    You do need to meet the criteria I stated in https://theartofsound.net/forum/show...63#post1035463
    From tests the value needed is around 1.8 ohms or a little less. You could try 2 off 3.3 ohms in parallel giving 1.65 ohms. A 3 watt resistor is a large enough rating.
    The difficulty with specifying the exact resistor value is that the relationship with increasing current is not linear, as it's dependant on the characteristics of the first FET.
  8. #118
    I'm Keith.
    Thanks chaps, they are the resistors I was thinking about. Mine are 10R 6.5W so will try some as Alan suggests.
    How Do I tell which rectifier I have fitted. There is nothing to see on the 4 that go across the width of the board at the cap end.
    Fets are mounted to floor of case as has been done in the recent builds on this thread, will check the tx.
    1M and 220k resistors are Riken Ohm and the 220r are Shinkoh so as good as it gets already unless going to z-foils or AN silver. Nick at Hificollective said not really worth it.
    Keith
    Aqua La Voce dac
    Salas DCB1
  9. #119
    Bigman80 Guest
    Keith
    Not much needs doing in that case. The resistors are fine!!
    Alan and I are going to do some resistor value tests to get to 1.2A so as soon as we have them in place I'll update the thread.
    As Alan said, this is going to largely be guesswork due to the slightly differing relationship with the FET.
  10. #120
    Keith
    Hi Keith,
    My assumption was that you had a standard build, didn't realize you had Riken and Shinkoh already fitted!!
    as for not being worth doing, i changed dale resistor to Audio Note Tantalum and there was quite a difference.
    My assumption would be the 4 rectifiers you already have fitted are Mur 820 or 860 but cant say for definite,
    S.
    Turntable; Rega p8
    Speakers; Rega Rx3
