Anyone checked the speed of their GL75 at 33 1/3 rpm (or any other speed) on their turntable?
Checking mine soon when I've finished the refurb, and will adjust as necessary.
Gary
Gary
How are you going to check the speed Gary ?
Regards
Brian
Amplifier : Sony TA FB740R
Speakers : Tannoy 637
Thanks Don , I'll do the download in the morning and take your advice on running the turntable for an hour .
Regards
Brian
I have a Goldring Lenco strobe disk I use on mine.
You can unscrew the whole idler arm mechanism which holds your idler wheel and set it a specific distance which generates exactly 33.3rpm, the value escapes me but it was published on LH only a couple of weeks ago. Not much help I know but might prove an easier way to control the speed of your 75 rather than relying on the speed selector mechanism.
I'm Andy.
I use the strobe and a bulb and works a treat.
Regarding the setting of the speed (and also checking the angle of the wheel is correct) on the Lenco Heaven site there are steps on how to build a device for this.
Here's mine in use:
Main system:
Analogue.
Network Player.
Digital.
Philips DCC 730 player
Marantz CD50SE
Amp.
Audiolab 8000A
Speakers.
Reiver Jenna floor standers
HeadPhones.
I'm Bikram.
