on cd's its often the amp/speaker combo. on vinyl its usually bad setup or duff cart/stylus, or a mix of both, or again amp/speaker interaction; ie the amp is struggling to provide enough current
I'm Paul.
https://www.youtube.com/watch?v=WoDamvrfUbQ
Listen to the very first bars of this youtube sample and you will hear exactly what I mean. It must be cymbal, but it goes psssssssst.
Can't tell anything listening to some rotten You tube transfer on laptop speakers. And I don't have that song on vinyl or cd to compare. Have you got this on vinyl? https://www.youtube.com/watch?v=jJ9Xk-VoGqo if so try it, if it's making a mess of that ride cymbal that goes on all the way through then it's some sort of issue with your turntable set-up.
Sibilance can be caused by poor quality interconnect cables. I had the same problem with sibilance until I invested in good quality interconnects.
GrahamS - It's not what you hear that counts, it's what you think you hear........
Present Kit: NAD 326BEE, NAD C515BEE CD player, JVC QL-7 DD turntable, JVC Tonearm, Shure M97Ve, Audio Technica AT95EX, Pickering V15, JVC Z1E, Wharfedale Diamond 230s, Visual Rio interconnects and My Ears.
I bought the single when it came out, bought the album, and have it on a couple of best of's, on vinyl and CD, and I can tell you that spitty-sounding "cymbal" has ALWAYS been there. I was always aware of this and just accepted it as part of the song.
What sounds interesting and a bit different to one person can sound gratingly wrong to another. I would suggest either learning to live with it, or just skip over to the next track.
