Right !! Lets cut to the chase
Now meticulously set up and with about 4hrs on it. I will say categorically that this cart is gorgeous !!
Like the Shibata Candeza Black it was, it is detailed, accurate non fatiguing and digs the music right out of the grooves.
Now with the Fritz Gyger S replacing the Shibata, this Replicant stylus profile is even more neutral, very beautifully neutral.
Even more detailed in that it digs out even more which is seriously some praise over the Shibata Cadenza which is a detail daddy.
Every instrument is in it's own space, textures are spot on but absolutley even right across the frequency range and that includes vocals which are soooo human and right , expression you name it.
Digs soooo deeep, so clean unscrathced records please as nicks and ticks are picked up if there.
Another thing is the improved stop start of rythmic movement and the dynamic drop of things like rim shots etc which now sound even more 'stick against rim' like, samely snare texture is so much more snare - slap / lick like......
There is also a quietness / calmness to the presentation which is great - I can turn up more without 'noisiness'
To say I am proper glad I took up Angus's recommendation to have the Fritz Gyger S re-tip is an understatement and a half.
He had it done on his Ortofon Vienna and was seriously impressed.
As he also said at the time, it is the best money I could have spent.
A stylus profile that is as the Replicant as used on Ortofons top flight carts costing thousands - I can only say that this is a no brainer upgrade (cause that is what it definitely is) and at less than half the circa £950 Ortofon are asking for to refurb the Cadenza B, I mean what more can I say.
Curtis Mayfield doing the business as we speak, the music is so non-fatiguing, engaging, beautifully and accurately textured instruments.
and only 4hrs on - Kilian recommended circa 14hrs burn in - you mean things are gonna get better !?!
Thank God I'm all set-up and back in music
