Results 1 to 10 of 14
Thread: Is this a ferrofluid tweeter ?
    Default Is this a ferrofluid tweeter ?
    I have these lovely Telefunken TL800 speakers and one of which has an issue with one super tweeter, it tests fine with the multi meter , I have replaced the caps to it , I have resoldered the joints , so I’m now thinking perhaps I just can’t hear it ( I can hear it on the other speaker ) .
    Could this be a possibility if it is a ferrofluid tweeter in need of new fluid ?
    If this isn’t the case then they will soon appear in private exhibitions
    if its a supertweeyer you shouldnt really be able to hear it;just feel its presence. might be the one you can hear has wrong value cap
    Highly unlikely that ferrofluid was used in a tweeter that old.
    Cheers guys , been pulling my little bit of hair out , I’ll now do the caps in the other one then compare .
    I'm Deleted.
    Grant is right, in theory, but you can hear something from all the super tweeters I’ve ever encountered.
    Account Deleted
    Well I’ve now replaced the caps in the other one and it’s working properly and I can hear the super tweeter, interestingly all the old caps tested fine too.
    I have since removed the offending ST and rigged it up in line with a capacitor directly to the speaker wire and it IS working! So I am flummoxed .
    Broken wire? If the crossover is on a pcb check for cracked tracks, I had that in a sloppily mounted crossover board.
    I replaced the wires too , could be a cracked track but I can’t see it if that is the case .
    I'm Deleted.
    Dry solder joint?
    Account Deleted
    Dry solder joint?
    Resoldered them all in the super tweeter circuit .
    Cheers Mark
    Given up now , they’ve beaten me .
