Hi All, need to replace the tweeters in my 442's. Does anyone know the part nos and where I can get them.
I contacted FA but no reply to date.
Many thanks, Martin
Many thanks, Martin
The originals are MB Quart items and are fragile (as you’ve found!) and long discontinued. Your best bet is probably to contact Lockwood Audio who specialise in pre-Audio Partnership Mordaunt Short and might be able to advise an alternative.
As I recall there is an unofficial ‘official’ replacement and I’m sure the 442s I owned had these fitted, but I can’t remember what they were - sorry!
As I said on the other thread these look the sane as those on the MS 25ti, 35ti etc I'd give them a shot.
Here's a close up and the back, if they look the same you can buy a pair of whole speakers for less.
https://www.hifi-forsale.co.uk/mobil...04&prodt=Genex
These aren't far from you
https://rover.ebay.com/rover/0/0/0?m...2F264000276223
